11-17-2019
21:34
11:42
11-17-2019
21:34
11:42
I have the fit bit charge to. I have been researching for the last few hours. But I have come up with nothing for my troubles though I am having with it. The firmware is up-to-date. And I have reset the fit bit at least 10 to 20 times. My issue is that there is no display at all. It will not display the battery level. Nor will it display the fit bit logo when I reset the device. I had this issue at least twice before period but the device seemed to have corrected it self Just by doing a reset. I'm fortunately. Doing a reset is not working. The device functions as should. Just no display. I unpaired it with my phone. To see if I could get the display to kick in by having the 4 digit code sent to the device to Pair it again. But unfortunately. There still is no this way. I am at a loss here. Is there anyone that would be able to help me get this figured out before I just go ahead and buy another one.
11-17-2019 21:47
11-17-2019 21:47
I used speak to text. Sorry for the fumbled words.
Any help would be greatly appreciated. Thanks in advance.
Best Answer11-18-2019 22:21
11-18-2019 22:21
I have exactly the same issue. Hopefully we can get an answer that will help rectify 👍
