12-16-2019
04:29
10:32
12-16-2019
04:29
10:32
I've had the charge 3 for several months, tried EVERYTHING I've found online to reset it, etc. Even uninstalled and reinstalled the app several times. The low battery notification is turned on for ALL platforms (email, text, push) but I have yet to ever get a notification that my battery is low.
12-16-2019 12:40
12-16-2019 12:40
How often does your tracker sync. Next time force a sync while you know the battery is low.
Best Answer12-16-2019 12:44
12-16-2019 12:44
It syncs all the time.
Best Answer12-17-2019 10:59 - edited 05-23-2025 06:10
Hi there @theonlynikki. Thanks for checking the settings to make sure you have notifications enable. Nice way to go!
Go to this page (notifications) and make sure that the notifications for low battery are on for both mobile and email. If they are, please turn them off and save the changes. Then, turn them back on and save. You should receive notification afterwards!
On the tracker, check your battery level at any time: from the clock face, swipe up. The battery level icon is in the top-left corner of the screen.
Your tracker continues to track your activity until your battery runs out.
Thanks for your help @Rich_Laue.
Best Answer12-17-2019 11:24
12-17-2019 11:24
Ok. I've tried this before, but I'll try it again.
thanks
Best Answer12-17-2019 11:26 - edited 05-23-2025 06:10
Sure thing @theonlynikki. Give it one last shot and let me know if this time it works.
You can also try restarting your Charge 3 before making the changes in the settings. In order to do so, see: How do I restart my Fitbit device?
Keep me in the loop!
Best Answer12-19-2019 13:52
12-19-2019 13:52
This did not work. My Fitbit just died without warning
Best Answer12-20-2019 07:31 - edited 05-23-2025 06:10
Hi there @theonlynikki, thanks for getting back and letting me know the outcome.
I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you soon!
Let me know if you have any questions present.
Best Answer12-20-2019 07:53
01-17-2020 07:55
01-17-2020 07:55
Still not working and no one was able to give me anything that worked.
