07-09-2022
12:57
18:55
EdsonFitbit
07-09-2022
12:57
18:55
EdsonFitbit
HI Everyone,
Change 2 with iPhone. On Fitbit screen it is stuck on switching on/off button for notifications. I will not let me click on anything else. I have held down the side button for more than 10 seconds and it will go to time screen for a quick second then right back to notifications on and off. The ONLY time it is not doing this back and forth is if it is on the charging station. A week a go it was doing this same thing except was switching between ALL screens, I took it off and cleaned the sensor and it stopped. Didn't help this time. Not sure how to restart my Fitbit (that would be my next thought). Thank you for your time.
Welcome to the Fitbit Community, @Hisheart.
Thank you for informing us about the difficulties you experienced with your Fitbit Charge 2 and for the troubleshooting steps you’ve performed.
In this case, I would recommend setting up your Tracker as a replacement device:
Hope this helps.
Best AnswerI uninstalled the app and reinstalled but it did not work. It is still turning notifications on/off constantly. You cannot do nothing on the Fitbit itself. The only time it stops for seconds is if you hold down the button on the side or when it is on the charging station.
Thank you for your help!
Thanks for your response, @Hisheart.
If you set up your Fitbit Charge 2 as a replacement device by following the instructions shared above without luck, the best way to get help for this problem is to chat with us online or give us a call. Please click here to get connected.
Have a nice day.
Best AnswerHi Fitbit, I literally have the exact same problem. I have tried the solution above but the problem still persists.
