04-03-2017
11:10
09:49
04-03-2017
11:10
09:49
My notifications won't pair with my I phone. It did when I first got. it is paired with the phone but not notifications will not pair
04-03-2017 11:17
04-03-2017 11:17
@Calvinclyd1, I am not sure exactly what you mean that the Notifications will not "pair" with your phone - the Notifications don't pair with anything, they are just sent via Bluetooth from your phone to your tracker. If your tracker is connected to your app, and you can sync your tracker with the app, it is paired okay. Have you checked your Charge 2 tracker to ensure Notifications has not been disabled? Press & Hold the side button for about 3 seconds to toggle the Notifications from Off to On.
04-03-2017 11:20
04-03-2017 11:20
@Calvinclyd1 The steps below should help you with receiving notifications on your Charge 2:
Hope this helps you out!
05-27-2018 22:40
05-27-2018 22:40
Notifications won't pair how do i make this happen
01-04-2019 15:17
01-04-2019 15:17
I just received my Charge 3, and it also won't receive "Notifications". When I click on Notifications from the iPhone app the message "Bluetooth Pairing Required". However, it is paired.
01-21-2019 16:43
01-21-2019 16:43
I was having the same issue. Here’s what worked for me:
Go to your phone’s Settings and into Bluetooth.
Find your Fitbit Charge and click on the button to “forget” it.
Make sure that your Bluetooth is still turned on and go into your Fitbit app. It should ask you to pair it with Bluetooth again.
I could get into the notifications screen no problem after that. Hope it helps (if you haven’t already worked things out).
03-01-2019 22:11
03-01-2019 22:11
THANKYOU!!
02-04-2020 01:45
02-04-2020 01:45
Cheers worked for me👍
