05-17-2020
19:42
08:53
05-17-2020
19:42
08:53
Was doing outside chores yesterday, took my watch off when I came in to shower & I'm not sure what happened. The red light will stay on, even after restarting. I tried restarting again & the light was off, but then it shut off. It has worked perfectly fine until then. I have it in rice on case it got moisture in it, but I thought they were waterproof? I had the watch on while washing my dogs, that's it. I don't know what to do & I depend on my Fitbit for daily use.
06-04-2020 18:20
06-04-2020 18:20
Mine did the same thing. It got wet and red light came on on the back and is staying on which drains the battery. I can charge it but it goes down pretty fast. I’ve tried rebooting several times to no avail. The red light stays on.
06-16-2020 08:15
06-16-2020 08:15
My Fitbit 3 is nearly a year old. It just started going "beserk" last week. The light is on all the time. Mine changes color . (ha) Have you heard anything about the problem or fix?
Best Answer06-16-2020 08:20
06-16-2020 08:20
