08-27-2019
14:57
05:36
08-27-2019
14:57
05:36
Hi @Steptripper. Welcome on board!
Thanks for letting me know about the reminders to move on your Charge 3, and let's work on this together. Before anything else, please verify that your Fitbit device and the Fitbit app are updated to the latest version. Once that is done, I'd recommend to try the following steps:
Wait for the next 10 minutes before the hour to see if you get the reminders to move. Please note that you'll get the reminder if you haven't walked 250 steps by then.
12:38
05:37
10-08-2019
12:38
05:37
Hi @MPS49. It's nice to see you around the Community.
Thanks for letting me know that you're having a similar issue, as well for trying the steps posted above. I'm sorry that they didn't work correctly, and let me explain that our team has received feedback about this situation experienced by other users. They're currently working on this to bring a solution as quickly as possible. In the meantime, we recommend to keep your Fitbit device and Fitbit app updated.
I appreciate your patience and don't hesitate to reply back if you have another question.
Best AnswerI’ve also had this issue for about a year. I have done EVERYTHING you’ve said. Restarting the fitbit makes it work consistently for about a day or two at most, then it begins skipping hours. I even tried a workaround by setting a silent alarm for each hour, but it won’t let you have that many. It’s maddening.
Best AnswerYeah, that’s not my problem. My only reminders now are wake up and bedtime and I’ve reset everything since. I’m glad to hear you may have found a fix, though!
