03-10-2017
13:28
20:15
03-10-2017
13:28
20:15
Fitbit should seriously think of having a Repair center for products.
My Charge HR has just gone over 365 days before the strap started bulging and finally the sensor does not work at all.
As it is out of warranty even though I want to pay for repir it cannot be done so have to decide.
Do i go for another charge and possibly be in same position year down the line or swap for another product or make
09-11-2020 15:43
09-11-2020 15:43
Customer center's standard reply is - they will check warranty option and will get back thru email but i did not an email. How unfortunate that my 15 month old versa just went dead and can no longer be used because there is no repair center. Common problem of fitbit devices that i have read
10-03-2020 01:12
10-03-2020 01:12
Hi my fitbit3 is just under 1 year fr purchase n its screen is dimming and hardly visible. I bought this from Tangs. Pl advise how i can fix this and whether the warranty covers. Thank u.
QS
Best Answer10-03-2020 04:33
10-03-2020 04:33
Best Answer10-03-2020 07:04
10-03-2020 07:04
Best Answer10-04-2020 12:46
10-04-2020 12:46
Best Answer10-04-2020 12:47
10-04-2020 12:47
Best Answer10-04-2020 12:48 - edited 10-04-2020 12:49
Tell them to replace it or buy it back. Doesn't matter if you have warranty or not, they will.
don't ever ever buy an extended warranty on anything, they are ripoffs.
Best Answer10-05-2020 15:10
10-05-2020 15:10
Best Answer09-07-2022 04:51
09-07-2022 04:51
The plastic part that holds my Charge 4 has broken. YES BROKEN after only 2 years of careful use. And all I got from support is a "you can't fix it" solution? So the product is now useless? Sorry but this sort of after sales support is a no go for me. There is no way I will ever buy a Fitbit device again. Charge 4 was a total fail purchase. There was a huge gap between the band and the device that was ugly as hell, and probably that was the main reason that I had it broken so quick. I will never suggest Fitbit to anyone.
