Replacement Charge 3 setup
I am trying to setup my replacement charge 3 and don't know what the 4 boxes ...it says to pair it up?
8 REPLIES 8
Hi @Caroldv  you should be setting up as a replacement device on an existing account. Click to learn more.
Stepping in the U.S.A. since September 2013. Android 14
Welcome to the Community, @Caroldv. I appreciate the input @Odyssey13 😀
@Caroldv Are you referring to 4 empty boxes on the Fitbit app? If you're following the steps listed here to setup your replacement, those 4 boxes on the app are for the pair code that your phone sends to your Charge 3 so you can pair your device. You'll see that 4 digit code on your Charge 3's display.
See you around.
If my post was helpful, you can vote for it. You can also mark it as Best Answer if it was what you were looking for!
Thanks for that explanation but my replacement charge 3 is fully charged
but dead. Even plugged in it is dead.
I am gutted.
Cheers, Carol
Thanks but have tried that!  No matter what I do, the watch is dead...does not respond to anything!
Thanks but I have done that over and over and the watch does not respond.
I am sick of it and going to put it in the rubbish bin I think.
Hi, @Caroldv.
Thanks for the update. I've seen you reached out to our Support Team and it seems that your Charge 3 was showing the setup message but you were having trouble with the setup process. I recommend you to contact them back so they can continue assisting you.
Catch you later.
Hi there, thanks for reply but honestly, I just can't be bothered
spending any more time on this watch.
Did all that several times... no help and still not working.
I am going to look at other brands as nothing I do seems to solve problems.
Moderator Edit: Merged replies
Hello, @Caroldv.
If your replacement is still having trouble to pair with your account and you received it recently, the best option is to update your case with our Support team so they can look for a resolution. Please explain them what you've tried so far so they can check your options.
See you around.
