05-20-2019
14:20
16:10
05-20-2019
14:20
16:10
Just received a replacement charge2 under warranty after the last one stopped working,problem is this one will not sync.now this has to go back after numerous attempts and emails.so anyway just wondering how good the charge2 is? am I just unlucky or is there a bad batch in circulation?
Where you able to connect the Charge 2 to your account, if you where, at this time it did sync.
As for a bad batch did you receive both the old and replacement about the same time through the same source? It has been about a year since the Charge 2 was made.
Best AnswerA couple of questions
What device are you using to setup your Charge 2, phone or computer? And what OS is it running.
At what point of the setup process does the failure occur?
Have you tried any of the troubleshooting tips? Some tips users have added that are not found in the help doc?
Best AnswerI am not an iOS fan so will not be able to help ot much.
Have you tried restarting the Charge 2 and phone?
Maybe remove the Fitbit app and install a fresh copy?
The setup message will continue to show until the unit is setup.
You say that it will not pair at all. Where does the setup process fail?
Does the Fitbit app find the Charge 2?
Does the Charge 2 respond with a 4 digit code?
Does the Fitbit app allow you to enter the 4 digit code?
Does the app then simply hang up, not responding?
Normally after the app had setup the tracker to your account, then the app will ask for permission so that it can pair the tracker to the phone.
Make sure that this Charge 2 doesn't show as a trusted device on any bluetooth list of devices on the phone or ipad.
It also would be helpful If the title included iOS
Best AnswerMy only problem with the Charge 2 is that it scratches easily and then got a crack that ran diagonally across the face. They wouldn't replace it--said you needed accident protection!
@Chamley74 wrote:Just received a replacement charge2 under warranty after the last one stopped working,problem is this one will not sync.now this has to go back after numerous attempts and emails.so anyway just wondering how good the charge2 is? am I just unlucky or is there a bad batch in circulation?
Best Answer@MissSharon normally that would be the case with most devices. Some retailers also offer insurance.
Best Answer@MissSharon did you contact Square Trade or Fitbit.
The warranty is with Square Trade and you need to contact them.
