04-27-2020
10:20
09:49
04-27-2020
10:20
09:49
I have a charge 2 that I have not used in two years. I charged it and the date and times are wrong. How do I reset to current date and time.
Hi @GrammyKat you can try restarting it a few times and be sure the firmware is current. Two years is a long time to have a dead battery. Also, be sure your phone is compatible, as the time on your device comes from the the phone or computer you use to sync the data.
Best AnswerDid you try syncing it a few times? The time and date come from your phone or computer.
Best AnswerIf you tried restarting the device and you've been syncing it several times, there's not much more you can do.
