10-12-2018
09:23
15:06
10-12-2018
09:23
15:06
Can we get an improvement to restart the Charge 3 without the cable? It seems to disconnect from the phone pretty regularly and I don't carry the cable with me since the battery life is so long.
Thanks-
02-13-2019 17:40
02-13-2019 17:40
Great answer ever. @Digityman
It is the first time my tracker freeze on a Whatsapp notification, and cable is at the office 😐
Swapping Clock face clears the screen and everything goes to normal.
Thanks
03-05-2019 11:00
03-05-2019 11:00
There ought to be a way to mark Digityman's suggestion as an acceptable fix! Changing clock face restored functionality to the screen on my Charge 3. Thanks!
03-21-2019 03:42
03-21-2019 03:42
Hey. My fitbit won't charge, and i can't do anything with it. I can see what time it is, and my pulse.. But other than that I can't swipe or anything 😞 So I have no idea what I can do to fix it. Since it can't charge, i can't restart it.. Help please! Ps: this is the first time it wouldn't charge.
Best Answer03-21-2019 07:34
03-21-2019 07:34
ps: Its 100% charged, but can't swipe or anything. So when I plug it in, the charger symbol won't show..
Best Answer03-21-2019 07:41
03-21-2019 07:41
Try swapping the clock face from your Phone App
03-21-2019 12:31
03-21-2019 12:31
04-09-2019 11:32
04-09-2019 11:32
+1 on Digityman's for "changed the watch face to something different and it acts like a little reboot."
04-14-2019 04:34
04-14-2019 04:34
Screen is black and won't respond. How does "Settings -> About -> Reboot Device" help that if I can't get to it..
Or if you are talking about that path in the Fitbit app on the phone, I am not seeing that.
Best Answer04-16-2019 13:11
04-16-2019 13:11
ugh my charge 3 has died on me twice, during challenges. I don't have my charger with me. But even last time, with the charger, it took several tries to reset it. I'm very frustrated with this product.
Best Answer04-16-2019 13:22
04-16-2019 13:22
@Randrich wrote:Screen is black and won't respond. How does "Settings -> About -> Reboot Device" help that if I can't get to it..
@Randrich -- have you tried going to the app and changing the clock face to something else and then syncing? Several others in this thread report that acts as a 'mini-reboot.'
Hope you get it working soon.
Scott | Baltimore MD
Best Answer07-02-2019 16:35
07-02-2019 16:35
Hello! This is pretty basic stuff. I’m on vacation in Mexico and my Fitbit is no longer paired. I don’t travel with the cable. Consider. Strongly consider a fix to allow pairing without the silly charging cord.
Best Answer12-04-2019 01:12
12-04-2019 01:12
The so-called "Best Answer" is an answer that says that there is no answer to the question. 🙄 Luckily, there is a solution, even if the "Best Answer" is not what solved the problem. Thank you so much, Digityman, for the solution that actually solved the problem. Watch-face-changing for the win!
01-04-2020 10:21
01-04-2020 10:21
Changing the clock face was the simples solution.
Best Answer01-04-2020 17:31
01-04-2020 17:31
Try changing the Clock face from your fitbit app on your phone. I had the same issue and it worked out very well. Now I can swipe on the screen.
Best Answer06-01-2021 12:00
06-01-2021 12:00
I restarted my charge 3 using your instructions but it didn't show results until I restarted my phone. Then it synced perfectly and quickly. I would suggest you add rebooting one's phone as well as restarting the tracker to get the tracker to sync. Thank you, I'm a happy camper. 🙂
06-03-2021
06:07
06:31
06-03-2021
06:07
06:31
Hello everyone. @Lady-Jenn Welcome to the community forums.
Thank you very much for the information and for your input. In case your Charge 3 experiences any syncing inconveniences, I recommend checking this help article for troubleshooting steps: Why won't my Fitbit device sync?
