10-15-2018
20:29
15:06
10-15-2018
20:29
15:06
Is there any way to restart the Charge 3 without it being on the charger? Today mine stopped syncing while I was at work, so I needed to restart it, but I couldn't because I left my charger at home.
10-15-2018 20:47
10-15-2018 20:47
I'm sorry but you need the charger to do it.
You can always buy an extra in the store and have one at work.
Wendy | CA | Moto G6 Android
10-15-2018 20:47
10-15-2018 20:47
10-15-2018 21:22
10-15-2018 21:22
Thanks Wendy. I was afraid of that. It's sad that the only solution to solve this bug of Fitbit's is to spend more money on an accessory.
11-30-2018 20:34
11-30-2018 20:34
I agree. This is yet another flaw design of a FB product. Reset should be able to be performed without the charger.
04-09-2019 11:46
04-09-2019 11:46
Try changing clock face on phone's app. Your charge3 should refresh itself .
08-10-2019 17:33
08-10-2019 17:33
@tt8ng wrote:Try changing clock face on phone's app. Your charge3 should refresh itself .
Thanks. That worked for me.
09-20-2019 07:37
09-20-2019 07:37
This is such a great help! My fitbit every so often will start the stopwatch and buzz constantly and I never could make it stop at work. Thanks for the great tip!
Best Answer10-25-2019 10:45 - edited 10-25-2019 10:56
Changing clock face in the app worked on Inspire HR too. Odd that the sync button wouldn't work but changing clock face does. But it worked!
Also +1 there should be a way to restart without charger.
11-18-2019 14:40
11-18-2019 14:40
From the clock screen, swipe to the left until you find Settings. Tap on Settings. Scroll down until you fin About. Tap on About. Scroll down until you see Reboot device, tap on it. Then tap on the check mark. It will then reboot.
08-27-2020 04:58
08-27-2020 04:58
This worked for me on the inspire hr.
