07-21-2020
15:10
13:23
07-21-2020
15:10
13:23
I can see on fitbit that my resting heart rate is 55 now used to be 58 a few weeks ago. But over the last month I can see that the only time I'm even close to reaching around 55in heart rate is while sleeping. During the day my heart beat is always 70+.. I checked the app and not once during the day have I been under 65.
Isn't it supposed to be resting and not sleeping rate? Is there a way to fix it? I'm using my Fitbit pretty much the whole day and always sleeping with it. Only take it off to charge and back on as soon as possible
And does this effect my calories burned that my resting is so low why my hear beat even when I'm just laying on the couch is normally 20 beats higher.
07-21-2020 17:39
07-21-2020 17:39
What is my resting heart rate on my Fitbit device?
Resting heart rate is the number of times your heart beats per minute when you are still and well rested. This metric can be an important indicator of your fitness level and overall cardiovascular health. The typical resting heart-rate range for adult Fitbit users is 50-90 beats per minute. Active people often have a lower resting heart rate. For more information, see the Fitbit Blog.
Fitbit uses your heart-rate data from when you’re both awake and asleep to estimate your resting heart rate. For best results, wear your device to sleep.
07-21-2020 17:39
07-21-2020 17:39
07-22-2020 00:09 - edited 07-22-2020 00:20
Thanks so mine is not doing it correctly as I'm sleeping and not resting to reach 55.. I guess I will try a long restart.
07-22-2020 06:38
07-22-2020 06:38
@seljelid wrote:Thanks so mine is not doing it correctly as I'm sleeping and not resting to reach 55.. I guess I will try a long restart.
In original post, I thought your point was you never got below 55 when awake, disregarding when asleep.
