Greetings! I am trying to search my resting heart rate from May. May 14, 2021 to be exact. Just discovered a heart issue and I’m hoping that date might be helpful. When I go back day by day, it seems to end a few weeks earlier (naturally) than that.
Thank you all!
10-16-2021
05:28
12:24
10-16-2021
05:28
12:24
Hello @STPsteps and welcome to the Help forum. Have you tried either of these ways? Tap on your heart rate tile, then swipe up (and up and up) until you get to back to May 14. Or, expand the 30 day heart rate graph and rotate it to landscape view. I am an iPhone user and can choose a 1 wk, 1 mo, 3 mo, or 1yr view. Make a choice (the 3 mo view is not too busy), then swipe to the right to get back to May 2021. You should be able to see each day with a light touch and press. You can slide your finger to May 14.
Sometimes the Android and iOS displays are slightly different.
Laurie | Maryland
17:15
07:08
AlvaroFitbit
10-16-2021
17:15
07:08
AlvaroFitbit
Thanks so much, l’ll give it a try!
Moderator Edit: Personal info removed
