01-20-2017
08:43
10:13
01-20-2017
08:43
10:13
When I use the tracking on the device while walking the same route it gives different distances (anywhere from .48 to .66 which is a large discrepancy). When tracking a walk with the app on my phone it is at the most .01 or .02 different.
In which of the 3 ways are you tracking your walk?
Letting the tracker auto detect?
Using the manual start with GPS and carrying the phone?
Using the manual start without GPS?
Personally i feel a galf mile test probably is not long enough, but make sure your not making to many turns if using GPS.
Best AnswerIf I track using the manual mode on the tracker (auto detect is turned off) I get large differences in the distance walking the same route. If I track using the Track Your Exercise on the phone app the difference is minimal. I carry my phone with GPS enabled either way.
Best AnswerOK when tracking in manual mode, are you using the connected GPS, and get a map?
@Rich_Laue wrote:OK when tracking in manual mode, are you using the connected GPS, and get a map?
yes. And the line is much more wiggly than when I track just using the phone app.
Best AnswerI find i get a wiggly line with connected GPS when any of the following occurs.
-To many other programs are running in tge backgraound.
-The tracker has a low battery
-The phone has a low battery
- The phones memory has too many closed apps still in residence
- I havent restartef the phone in the last 5-7 days. Androids newd to be restarted at least once a week to release unused memory.
Im still looking for a hint as to which phone you have, since this is more than 50% of the problem.
@Rich_Laue wrote:I find i get a wiggly line with connected GPS when any of the following occurs.
It's a Motorola Droid Turbo (Android). It is fully charged as is the Fitbit. No other apps running. Just did a restart yesterday and the map today was still all wiggly.
Best AnswerDid you swipe the other programs out of memory?
Right now i have 2 programs running but 33 in memory which will affect the accuracy on my phone.
If your wiggly line is the same as mine - I think it shows where you actually walked, nobody walks in a dead straight line... If I expand out the map for my last walk I can see where I went off the track to take a photo and again later off the track to sit on a bench. Great stuff😉
@walcyclit wrote:If your wiggly line is the same as mine - I think it shows where you actually walked, nobody walks in a dead straight line... If I expand out the map for my last walk I can see where I went off the track to take a photo and again later off the track to sit on a bench. Great stuff😉
Yes no one walks in a perfectly straight line but I find it hard to believe the GPS can detect a difference of a few inches. Also it shows that I crossed the street when I didn't.
Best AnswerI have the same problem! My line based on manual tracking off my wrist tracker show me walking literally in circles, sometimes in the middle of a street! Distances are more variable but also, generally, shorter. My assumption is that the GPS on the phone just works better.
Best AnswerYes the Versa uses the phones Bluetooth. Since your posting in the Charge 2 forum for Charge 2 problems I expected you where asking about a Charge 2.
