11-18-2018
23:36
14:34
11-18-2018
23:36
14:34
I have just purchased a charge 3 & the display doesn't come on when I roll my wrist. I have to tap the charge for the screen to wake up. Is that how it should be. Thanks.
09-04-2020 10:13
09-04-2020 10:13
I never had to reboot my Charge 2 either. This is a disappointing product.
09-04-2020 11:38
09-04-2020 11:38
Of late, The wake feature or display on my Charge 3 doesn’t come on when I raise my Arm above chest level as was happening a few weeks ago. Now I have to tap or press the button below to see the display. How can I rectify the problem? Thanks in advance.
09-04-2020 11:45
09-04-2020 11:45
Thank you so much. I had to turn on the wake icon. Then it worked.
Best Answer09-04-2020 13:01
09-04-2020 13:01
I set up a chat with Fitbit and we troubleshooted for some time. Nothing worked for the issue you and I both have with our Charge 3. They are replacing it since it was under warranty.
Best Answer09-05-2020 00:02
09-05-2020 00:02
hello, my problem was resolved. By restarting and switching on the screen wake feature
Best Answer09-13-2020 04:56
09-13-2020 04:56
Hi, Marre
my fitbit charge 3 is not displaying anything on the screen, it has got a battery about 50% i can see in the app. I tried 8 sec restart and changing clock face also but nothing works. Please let me know what can be done
Best Answer09-22-2020 04:18
09-22-2020 04:18
I don't know if this affects you, but I was having the same problem. Then I realized it had gotten switched into Sleep mode. Go to the Quick Settings menu (hold side button for a second), and see if Sleep is highlighted. If so, tap it. Then screen wake option will be available. Hope it works!
09-22-2020 09:06
09-22-2020 09:06
Best Answer09-22-2020 09:07 - edited 09-22-2020 09:08
Best Answer09-23-2020 05:37 - last edited on 12-10-2020 17:53 by LiliyaFitbit
Thank you So much.
It’s rectified.
With best regards
Best Answer09-23-2020 09:34
09-23-2020 09:34
Hurray! An easy solution after all.
Best Answer10-09-2020 09:21
10-09-2020 09:21
Hi Good advice! Sleep mode disable Screen Wake feature. Many thanks. Too bad this is not highlighted better in manual!
Bye
10-20-2020 13:20
10-20-2020 13:20
Nope still did not work 😠🤬
Best Answer10-20-2020 21:14 - last edited on 12-10-2020 17:53 by LiliyaFitbit
Hello,
I could resolve the problem by completely resetting the device as directed
in trouble shooting section of the device. Then I switched OFF and again ON
the screen wake icon once again. Then it worked fine.
Hope this solves your problem.
With best regards
Best Answer10-20-2020 22:16
10-20-2020 22:16
Best Answer10-21-2020 02:51 - last edited on 12-10-2020 17:54 by LiliyaFitbit
Great. Enjoy your FITBIT --
With best regards
Best Answer11-02-2020 08:18
11-02-2020 08:18
This solution didn't work for me. Despite restarting, the wake bulb is gray -- doesn't respond to tapping. Will appreciate any additional advice.
Best Answer12-09-2020 11:57
12-09-2020 11:57
I have tried the fix mentioned in this thread and it doesn't work for me. The screen wake & DND icons are both grayed out and don't respond to my touch. Also, as others have mentioned, there is no option to turn off Quick View in the app. I second the opinion that this is a flawed product and should not be on the market if it doesn't work properly. Also, can one turn the watch off. I saw that listed as a fix as well.
12-13-2020 16:51 - edited 12-13-2020 16:52
Where is the option to turn off Quick View?
The best solution is update firmware to display either Sleep On, Sleep Off, Wake On, Wake Off, DND On, DND off. Since screen brightness is so poor I can’t tell what’s on or off. Take out the guesswork please.
12-13-2020 19:10
12-13-2020 19:10
Thanks! That solved the problem!
