04-19-2016
08:09
17:01
04-19-2016
08:09
17:01
04-19-2016 13:19
04-19-2016 13:19
Hi @Joshua45431
Feel free to contact the Fitbit Support Team (Click / Tap here to contact)
Optionally check out Returns & Warranty before contacting support.
Best Answer04-25-2016 11:22
04-25-2016 11:22
I'm having the same issues. I bought it less than 3 months ago and have 2 cracks in it. The first crack actually chipped off this morning. Have you contacted customer service? I am interested to see what they say.
07:57
04:27
04-27-2016
07:57
04:27
Welcome to the Fitbit Community @Joshua45431 and @erin_paige. If your Fitbit Charge is also cracking @erin_paige please contact our Support Team. They will take good care of you
Keep me posted.
Best Answer07-27-2016 19:14
07-27-2016 19:14
Yes! Mine is just 3 months old and the corner is almost cracked off! I emailed them. Hopefully they replace it because this was definitely not something I caused. Never dropped it or hit it on anything!
Best Answer07-30-2016 05:28
07-30-2016 05:28
Same/similar problem here! My first one cracked on the left side, a piece that eventually chipped off...I didn't get to speak to Support though as I then had an accident and broke the thing completely!
But my new one (less than a month old) now has the start of a crack inside the screen on the left side (odd that it happened in the same place, bearing in mind I wear it on my left arm, so it is very protected by my chunky arms!
). No damage has happened to it, as I am very overprotective of my gadgets!
05:52
04:27
08-06-2016
05:52
04:27
Welcome! It's great to see you around @brittanyyydiaz and @sophiahello. Thank you for letting us know that you have already contacted Support @brittanyyydiaz, they will take good care of you! ![]()
@sophiahello, if your first tracker is still under Warranty you can still contact Support. I would recommend to contact them in order to get a positive resolution for both devices.
Catch you later.
Best Answer04-16-2017 01:46
04-16-2017 01:46
Hi Joshua, same for my wife, her three month old Charge 2 suddenly developed a vertical crack down middle of screen. I think it is a design fault caused by the screen expanding quicker than the casing when outside in hot sunshine.
She has not dropped or hit anything with the device, the casing is as good as new, just the screen damage.
Jon.
Best Answer06-06-2019 05:01
06-06-2019 05:01
Fitbit Charge 3 users: there are no replacement parts and no repair options for a Charge 3 cracked screen! Buyer beware!
