04-10-2020
23:51
16:20
04-10-2020
23:51
16:20
Will the screen timeout be adjustable in the Charge 4? This feature was one of the two most requested fixes in the Community forum for the Charge 3.
10-10-2020 19:40
10-10-2020 19:40
YEA -just when I was thinking of returning my new Charge 4 since the screen went off so much quicker than my Charge 2, I got a software update and now found it - totally fine the battery life is shorter 🙂 I switched it to LONG !!! Version #20001.96.29
10-12-2020 16:12
10-12-2020 16:12
Swipe watch left to settings.
Swipe up to screen time.
Choose 3, 5, 8 seconds.
11-14-2020 10:57
11-14-2020 10:57
When I'm jogging, I want it on for the whole time. Long = 8 seconds is a joke for anyone doing track workouts.
Best Answer11-28-2020 16:56
11-28-2020 16:56
I think there should be an option for at least the analogue clockfaces to remain on permanently.
You can vote for an always on display for the fitbit charge 4 here:
Best Answer12-26-2020 08:44
12-26-2020 08:44
Just bought a Charge 4 for Christmas and it did not have the Timeout Feature available. Syncing did not help and then today the app says there was an update available so updated the phone and all is good. The version when opened Christmas day was xxx1.94.13 and the upgrade took the phone to xxx1.96.29. So upgrade your Charge 4 and you should be good to go.
Best Answer12-31-2020 19:13
12-31-2020 19:13
I just received my Fitbit Charge 4 - and Very Disappointed and Frustrated with Screen Timeout; Too Short -3 Seconds ONLY.
it does not even fit the purpose as a Basic Watch!
Best Answer02-20-2021 10:01
02-20-2021 10:01
The latest firmware update issued today does allow for timeout adjustment. The “medium” setting gives you 5 sec which should be plenty without burning the battery charge too quickly.
22:32
07:10
JuanJoFitbit
04-24-2021
22:32
07:10
JuanJoFitbit
Hi, I'm running Firmware 48.20001.96.29, I went into settings on my Charge 4 wanting to lengthen the display timeout, swiped my way into the "screen timeout setting" and was presented with the screen below of which I now seem to be stuck on and can't leave no matter which way I swipe (or pressings of the side button?) ... even holding down side button for over 8 secs doesn't seem to be initialising a restart ?
Screen
Time Out
Increasing
screen time
reduces
battery life
I've only had the device for a couple of days, and am still waiting for the "Tap the pink Update button. This option only appears if an update is available" to show up in my app so the newer options like Dynamic GPS etc. will then hopefully be available ... Only purchased / did initial setup a couple of days ago. What is the latest firmware version? am I running it (see above) ?
Please I want out of this screen ! ... many thanks in advance
Solved it. It's just how much the button is recessed. I thought i was pushing it, but obviously wasn't pushing my fingertip deeply enough into the hollow.
All is well now, though I must say the button does seem to be a bit difficult to make proper contact with.
Thanks for reading tho
Moderator edit: merged reply
Best Answer06-05-2021 12:31
06-05-2021 12:31
Yes there is actually. It's under settings. Scroll down it's towards the bottom. Reads "SCREEN TIME OUT" tap it it tells you it drains the battery life. It will change to Medium, tap again it changes to Long
Best Answer06-15-2021 15:33
06-15-2021 15:33
I have a Charge 4. DaBigDog is correct. I was able to go to Medium (6 seconds).
06-16-2021 07:09
06-16-2021 07:09
3 seconds, 6 seconds, 9 seconds
Best Answer06-16-2021 17:15
06-16-2021 17:15
Sorry, but this is definitely not the best answer. It has no clear answer. Because of this post I almost gave up. But user DaBigDog and likely others described how to do it on a Charge 4. I changed my screen timeout to 6 seconds (Medium).
Best Answer02-13-2022 12:02
02-13-2022 12:02
Where do you find this option? Tells me it can be found in settings but haven't found it yet.
