11-11-2020
12:51
12:54
11-11-2020
12:51
12:54
I noticed this morning that my Fitbit Charge 3's screen was much, much dimmer than normal and that it was no longer responding to my finger taps to activate the screen. I have to push the side button to get it to show the time ... and I have to be in a dark room to be able to read it! I have rebooted it, and at first the smiley face was nice and bright, but then it went back to dim. And it still doesn't respond to taps.
11-11-2020 12:54
11-11-2020 12:54
Check it's not in Sleep Mode.
Best Answer11-11-2020 12:54
11-11-2020 12:54
Best Answer11-11-2020 13:33
11-11-2020 13:33
That was it! No idea how I got it into sleep mode... but if it happens again, I'll know what to do. Thank you so much.
11-11-2020 14:24
11-11-2020 14:24
Same thing with mine. It has been syncing for 8 hours and just finished. I just did a reset, the smiley face appeared nice and bright, and then it went dimly lit again (it is not in sleep mode).
Best Answer11-11-2020 16:21
11-11-2020 16:21
How do I know it is in sleep mode? I have no screen at all.
11-12-2020 05:10
11-12-2020 05:10
Hi, welcome to the Community forums @NJBean @okbotto @HappyQuilter, I'll be glad to help you with this.
Thank you for sharing this information about what you've been experiencing with the screen of the Charge 3 that is too dim.
@NJBean, it's great to know that you were able to resolve by disabling the Sleep Mode feature, thank you for sharing this update.
@okbotto , since you already tried to disable the Sleep Mode and the restart procedure, I've proceeded to send your information to the Customer Support team for further assistance; you should be getting a reply soon.
@HappyQuilter, this option should be available on the Quick Settings. Press and hold the button, and swipe left to access the quick settings screen.
When the sleep mode setting is on:
I've also been informed that you already contacted the Customer Support team about this, keep me posted on the outcome.
Let me know if you have further questions.
Best Answer11-20-2020 20:04
11-20-2020 20:04
May I ask, how did you get it out of sleep mode? I think that may be my problem. Thanks in advance
Best Answer11-20-2020 20:35
11-20-2020 20:35
@rrrrosie wrote:May I ask, how did you get it out of sleep mode? I think that may be my problem. Thanks in advance
You can always get to in 'Settings', but probably also if hold in side button a few seconds and look for 'Sleep' - might have to scroll down.
11-20-2020 20:35
11-20-2020 20:35
11-20-2020 22:14
11-20-2020 22:14
Many thanks, it worked
Best Answer11-22-2020 09:27
11-22-2020 09:27
Thank you!
12:13
05:43
DavideFitbit
11-22-2020
12:13
05:43
DavideFitbit
Same with me. Cant see the screen to know if it's in the sleep mode. sHould have access via iPhone
Like Happy Quilter, if you can't see the screen you can't see any settings. Why can't this be done on the Fitbit app on an iPhone.
11-26-2020 05:40
11-26-2020 05:40
Hi, sorry for the late response!
Thank you for sharing this update, it's great to know this has helpful for you @rrrrosie @Slownotdumb!
@HappyQuilter, could you please try to look for the Sleep Mode option while you are indoors? Let me know if you're still not able to see anything on the screen.
@DENBOAZ, it seems that you've contacted the Customer Support team about this as well, please keep me posted on the outcome.
Best Answer11-27-2020 10:19
11-27-2020 10:19
Best Answer11-28-2020 14:12
11-28-2020 14:12
Hi, thank you for your reply @HappyQuilter.
Thank you for confirming that you already tried the steps suggested earlier. I've gone ahead and sent your information again to the Customer Support team for further assistance, so you should be getting a reply soon.
