04-27-2020 08:33 - last edited on 12-14-2022 16:20 by MatthewFitbit
Hi All. My new Charge 4 was working fine, but I updated the software two days ago and now when I rotate my wrist my screen doesn't wake. I can only wake the screen when I press the "button." Anyone else having this problem or have a fix? Thanks!
04-27-2020 10:01 - edited 04-27-2020 10:08
@Batdork Is sleep or DND turned on?
Also, what @Rich_Laue is referring to is when you long press and hold the button for 2-3 seconds, there should be a screen that pops up that has screen wake listed there. It is next to the Fitbit pay menu. This is slightly different than the settings menu. This is the "Quick Settings" that he is talking about.
https://help.fitbit.com/articles/en_US/Help_article/2086#c4_adjustsettings
04-27-2020 08:43
04-27-2020 08:43
Hold your button in, swipe left, check your quick view setting.
04-27-2020 09:05
04-27-2020 09:05
Hey. Thanks for the response, but I don't see a "quick view" setting. I can get to settings, but within that category there's nothing for "quick view" or anything else that seems to apply to the screen waking when rotating my wrist. All I get within settings is brightness, vibrations, heart rate, do not disturb, sleep mode, heart zone alerts and about. Am I doing something wrong?
04-27-2020 10:21
04-27-2020 10:21
@SrRojo gah! I'm an idiot... I didn't scroll down. Just saw the sleep and dnd settings. Thank you so much for your help!! Stay safe and healthy!!
04-27-2020 10:57
04-27-2020 10:57
Phew I'm glad you found it! You stay safe too!
04-27-2020 11:01
04-27-2020 11:01
You may want to download your user manual from the help site.
08-29-2020 14:27
08-29-2020 14:27
I’m glad you were an idiot because so am I! I couldn’t find this darn screen wale setting for anything until I saw your post. Yay it’s finally working now! Thanks!
08-29-2020 14:56
08-29-2020 14:56
I'm glad I'm not the only one!! Happy the public airing of my cluelessness helped someone else.
09-17-2020 13:14
09-17-2020 13:14
You can add me to the list of idiots - until I saw your post on needing to scroll down to find the ‘screen wake’ setting, I was convinced the last firmware update had deleted that setting or I had a faulty product!!! So thank you - you helped me as well!
best
guy.
10-10-2020 09:29
10-10-2020 09:29
I cannot get the screen to swipe to the quick settings.
Freemont
11-01-2020 09:52
11-01-2020 09:52
thanks for asking this question because it was driving me nuts while swimming today. Now if fitbit woyld allow us to see our screen the entire time we are working out. It's very difficult to stop your stroke in order to flip your wrist the right way to see your screen for the less than 2 seconds it stays awake. May need to return it....
01-03-2021 10:04
01-03-2021 10:04
Video to treat the problem 👍
https://youtu.be/r2IfEZ7ogb8
01-24-2021 16:38
01-24-2021 16:38
You're not the only one! For several days I was struggling with the same problem. I did get to the "Quick Settings" and noticed the DND and Sleep options, but never realized I should scroll down to see the Screen Wake option ... I must have accidentally toggled this setting, perhaps while cleaning the device. I am relieved my pretty new Charge 4 isn't broken, but I really hope that new devices have a better user interface.
05-01-2021 09:41
05-01-2021 09:41
I found The screen and the icon with the line through it. But I cannot change it! I tap I swipe I cannot change it. Any advice? This **ahem** cost a lot of money for this to be happening
05-01-2021 10:41
05-01-2021 10:41
I've had this problem since about the first week. The only time it works is when I rollover in bed and do NOT want it to!
05-21-2021 13:51
05-21-2021 13:51
Thank you! This worked!
06-09-2021 05:18
06-09-2021 05:18
Old post but another new idiot here. I was searching for easily 1 hour or so and reading all the help pages etc. I know we have to press and hold the button to go to screen wake setting but i keep on seeing two pages only which is the fitbit pay and then swipe rite to see DND and Sleep option.... and i did not think of swiping down!!! What a total idiot!!! Lol... glad i manage to read so many forums and postings until yours one here that says... SCROLL DOWN !!!
06-27-2021 19:19
06-27-2021 19:19
I am having this same problem. My wake icon is grey nd won't let me change it. Did you find a solution¿
07-16-2021 10:16
07-16-2021 10:16
Problem solved! Thank you!
