10-07-2018
03:53
15:47
10-07-2018
03:53
15:47
Hi
I'm new to Fitbit and have the charge 3! I'm looking for some advice on how to set up notifications from WhatsApp and or Facebook messenger to my watch? I'm using an iPhone and have read some conflicting info on whether this is possible?
Thanks
@Bodders Welcome to the Fitbit family! Thanks for your interest in setting up Whatsapp or Facebook notifications on your Charge 3. It is no conflict at all!
Please follow these steps:
Check step 3, you will find it helpful. For more details on how to set up notifications; check this helpful article.
@SunsetRunner Thanks for sharing your help on this thread!
Hope this helps. Keep me posted! ![]()
You have to receive a notification from the relevant app before the app gets listed. So get a friend to message you and then they should appear in the list.
Sean | London, England
Charge 3, Blaze (Retired), One (Retired) / iPhone XS Max (iOS 12.2)
Please visit Fitbit Help if more help is needed
It wouldn’t show up in Fitbit app for me to select from either following the Fitbit steps.
These are the Steps that worked for me:
Have a friend send you a WhatsApp message that sends you a notification on your phone (make sure your phone is locked to it shows as a notification on lock screen)
reboot your phone
Then it will show in the fitbit app for you to choose from.
I do do not use Facebook messenger so i have only tried with WhatsApp.
i have have an iPhone 6 with iOS 12
10-16-2018
09:06
08:37
10-16-2018
09:06
08:37
@Aloishere Welcome to the Fitbit forums! Thanks for posting the situation you are experiencing with the Whatsapp option not showing when trying to set it up for your Charge 3. It should work fine for an iPhone 7.
Are you still experiencing the same?
It seems that @seantnash and @joni_marie posted some solutions above. I'd recommend trying them out as that should definitely help you out to get the Whatsapp option to show on the list.
Thanks for sharing your experiences on this thread.
Best AnswerStruggling to get WhatsApp and Facebook notifications on my new Charge 3 (as a complete Fitbit novice). I cannot even see these on the drop down to allow notifications.
Any help or advice please?
I receive WhatsApp notifications on my iPhone. After one day of Charge 3 use WhatsApp did show up in my app notification menu in the Fitbit app. I have set notifications on in that menu for WhatsApp and also set Notifications on, on my Charge 3 but I still don’t get WhatsApp notifications on my Charge 3. Any idea? I do get sms/texts. I don’t seem to get calendar notifications either and they are on too.
Appreciate the help.
Best AnswerI made this work. Adjusted the notification settings in WhatsApp and in the Fitbit app, to make the banners permanent and this seemed to have to have done the trick.
Thanks all.
Best AnswerEver since I updated my Fitbit charge 3 a few days ago, it does not stay connected to my iPhone and it get the message Bluetooth pairing failed call notifications and all-day sync are disabled for now. I still can manually sync.
Hi,
I have just purchased the Charge 3.
I have followed the above steps but i am still not receiving any notifications on my watch.
I have even checked my whatsapp notification setting to ensure its permanent but nothing?
I am also not receiving call notifications/ calendar or normal messages
Best AnswerHi. Had the same issue with Alta HR. Followed these to restart it https://help.fitbit.com/articles/en_US/Help_article/1186 and it works now.
Best AnswerThank you so much. This was super helpful!!!
I have a Galaxy S6 and Fitbit charge. I am getting notifications from all my desired apps except for the ringing of the phone. I thought when I first set it up it worked. Now when I go to select apps for notification the telephone isn't one of them. Help?
Best AnswerHi! I am still having an issue getting any all notifications sent to my new fitbit charge 3. I've gone into the account settings on the fitbit app and into the notifications section, but it won't pair once I get into the notifications section, nor does it give me the option to turn on any notifications in regards to phone calls, text messages, or facebook messenger. So it doesn't give me the option to turn on any of these settings. I have a LG Stylo 4 that has Android 8.1. Please let me know if there is anything I can try.
Thanks!
Best AnswerWhere at?
Best AnswerI'm unable to get notifications from android mobile, especially from whstsapp. WhatsApp icon is not highlighted to put :white_heavy_check_mark: mark
