05-30-2019
06:39
15:47
05-30-2019
06:39
15:47
I have a Charge 2 and it starts up with displaying version 22.53.04. It then goes to the www.fitbit.com/setup screen and gets stuck there. Trying to sync it on iphone, ipad or Macbook will just not work. It seems the Charge 2 can not be discovered.
Any tips on how to hard reset the Charge 2 or get it to work?
Pretty useless device if I can not connect to the app or even see the information on the device display?
05-31-2019
12:27
10:26
05-31-2019
12:27
10:26
Hi @JonasGotterbarm welcome to our Fitbit Community! I'm glad to help you with your Charge 2 setup difficulties.
Seems odd that you're unable to setup your device, even though there's no hard reset for this specific device as per your inquiry, if you haven't already done so, please try the following steps:1. Restart your Fitbit device.
2. After your Fitbit device has restarted, reboot your iOS device.
3. Open the Fitbit app, tap "Join Fitbit,” and then proceed through the setup process.
For more information on setting up your Fitbit device with the Fitbit app for iOS please go to: How do I set up my Fitbit device? and if necessary, check the troubleshooting steps from our help article: Why can't I set up my Fitbit device? and let me know how it goes.
I'll be here if you need anything else.
