01-12-2019
18:32
17:54
01-12-2019
18:32
17:54
Charge 2 was 6 months old when it died. Fitbit sent new charge 2... could not set-up. Sent it back..got another Charge 2. Would not set-up (used phone, tablet and PC). That was 6 weeks ago. No communication from Fitbit. Called this week... I was told "there may be a software update that will fix the issue." Or I can purchase an Ionic ($249.99) with a 40% discount (never sent me the link not that I was interested).
HOW ABOUT HONORING YOUR WARRANTY, FITBIT!
01-13-2019 16:31
01-13-2019 16:31
Thousands? If that's really the case that explains their lack of responsiveness, hoping we all go away.
01-13-2019 17:07
01-13-2019 17:07
I think it has something to do with programmed obsolescence
mine work but can’t record my peak heart rate. What use is it if it doesn’t do the job
01-13-2019 17:18
01-13-2019 17:18
Same here. Fitbit produces a piece of crap. I've have spent hours and hours on 3 different fitbits just trying to get them to work. This replacement won't setup no matter what I do. I followed ALL of their suggestions.
01-13-2019 20:37
01-13-2019 20:37
I had the same problem with my Fitbit charge 2. It worked for about 3 month then it started disconnecting. I have reset it on several occasion and it will not stay connect. This is definitely crappy product and I will NEVER purchase another Fitbit product.
Best Answer01-14-2019 02:00
01-14-2019 02:00
What’s the firmware number?
Best Answer01-14-2019 05:09
01-14-2019 05:09
Best Answer01-14-2019 05:10
01-14-2019 05:10
mine is 22.55.2
symptom: not recording peak heart rates
Best Answer01-14-2019 05:24
01-14-2019 05:24
chatting to support now.
Replacement Charge 2 pebble won't pair.
So i have to send it back.
My band has broken so they're sending me a new one.
So i get a whole charge 2 in 2 pieces. Of which 1 won't work, yet they can't send me a whole new charge 2.
It is insane
Best Answer01-14-2019 09:51
01-14-2019 09:51
Best Answer01-14-2019 09:59
01-14-2019 09:59
Best Answer01-15-2019 04:21
01-15-2019 04:21
They say it's the app that has a bug.
So apparently it takes more than 5-6 weeks to find the bug and fix it.
Why not just use the old OS for the app.
That one worked. So just update us with a downgraded version and problem fixed.
But's that's probably a way to simple fix
Best Answer01-15-2019 09:56
01-15-2019 09:56
They send you another piece of crap so you'll spend $250 on a new fitbit. I'll never give them another penny.
Best Answer01-15-2019 10:34
01-15-2019 10:34
Me neither! They couldn’t organise a booze up in a brewery!
pity there is a swear filter on here 😉
Best Answer01-15-2019 10:45
01-15-2019 10:45
Funny. I’ve been looking at purchasing a Charge 3, but I see lots of complaints. I guess I should count myself lucky, my Charge 2 works like a charm...
Best Answer01-15-2019 10:48
01-15-2019 10:48
Best Answer04-06-2019 17:30
04-06-2019 17:30
I had the same experience as Unhappy with 2 different Fitbits and then read on reviews that we are only 2 out of MANY people. They will send you a new Fitbit but it won't setup.. i am willing to spend whatever I need for a good tracker but obviously it won't be Fitbit. They send you a tracker that won't setup and then give you a great offer for a more expensive tracker. Great marketing but didn't work this time.
Best Answer05-03-2020 21:58
05-03-2020 21:58
I bought a Fitbit Ionic a year and two weeks ago and it have just got bricked. I've tried a factory reset as it was having some connection issues and puff. It never went on again. Customer services went through all the stuff that is already on the manual and I've tried before contract them. And then just told me that I have a dead device, not elegible for replacement. I cannot understand how a working device that went through a regular procedure, following the steps indicated in the manual get bricked and the company don't assume any responsibility. Please, just avoid Fitbit. It's overpriced when you considered what it last and the customer service they give you for that price
