11-30-2017
08:45
18:54
11-30-2017
08:45
18:54
I accidentally deleted a sleep log on my Fitbit app by mistake. Is there any way to retrieve it again?
12-02-2017 00:43
12-03-2017 10:44
12-03-2017 10:44
@LAFB40 Welcome to the Fitbit Community! I hope you're doing well! You can definitely log your sleep via the Fitbit website following @SunsetRunner's instructions. You can also try using the Fitbit app on your phone, just tap the sleep tile then on the top right corner tap the stopwatch with the plus sign and enter the information on the new screen.
Let me know how it goes!
Best Answer12-03-2017 12:14
12-03-2017 12:14
But no, you cannot retrieve it after you delete it.
Best Answer03-04-2020 00:41
03-04-2020 00:41
But being unable to retrieve my sleep app is crazy as it's the newest charge 3 fitbit there must be a way?
