04-27-2020
06:31
09:49
04-27-2020
06:31
09:49
Why do I keep getting the simple sleep tracker instead of the more detailed sleep information that I used to get?
04-27-2020 06:56
04-27-2020 06:56
I get nothing! Since the last debacle it has disappeared!
04-27-2020 09:29
04-27-2020 09:29
Have you tried the reset? Hold the button for 10-15 seconds and then you see the fitbit symbol and it gives you the firmware version? I've been doing that for awhile. I always do a sync first. It was working and then the period between resets got shorter. Now the reset is no longer working. These days I'm really only using my fitbit for my sleep tracking....
