03-04-2017 14:16 - last edited on 09-09-2020 09:49 by MatthewFitbit
My steps are not registering in my challenges. My dashboard is syncd and showing steps but not pulling through to challenges. Anyone have any idea?
05-21-2018 01:43
05-21-2018 01:43
Did you ever find a solution for this?
im having the same problem and nothing seems to help!
05-21-2018 03:20
05-21-2018 03:20
Sadly not for the original flex. I bought the flex2 and haven't had the issue since. My hubby uses the flex and still has the issue when he's in a challenge.
05-21-2018 05:45
05-21-2018 05:45
05-21-2018 07:46
05-21-2018 07:46
06-17-2018 10:52
06-17-2018 10:52
I have a Charge 2 and have tried the solution of posting a message but did not work. I am in challenges crossing time zones but the most recent challenge I have been in CST, the whole time while the challenge was started in PST. I'm missing a few thousand steps again in this challenge.
06-27-2018 12:47
06-27-2018 12:47
Why is this problem marked as solved when it is clearly not?
06-27-2018 22:43
06-27-2018 22:43
In general @gogig it is the original poster that marks the thread solved.
I would have to read the original post and the post that they marked solved.
As for as steps not transferring, many have found that manual steps will not transfer. Which is to keep the user from cheating.
I see this is your first post here, so I'm not sure what steps of yours are not transferring .
09-25-2018 05:43
09-25-2018 05:43
Mine is doing the same thing. I’ve gone into messages send a message that didn’t work. I turned off my phone turned back on. That didn’t work. I looked for updates, that didn’t work. The challenge is 62,500 steps, I have over 65,000 steps but my steps won’t sync to the challenge.
10-21-2018 00:31
10-21-2018 00:31
Didn’t work for my hr2
10-25-2018 20:13
10-25-2018 20:13
This fix did not help for me. But I fixed it some other way.
I quit the challenge and asked someone to re-invite me. Once I joined, all my steps showed up! Woohoo!!
07-17-2019 09:11
07-17-2019 09:11
Nope, didn’t work for me either.....
07-17-2019 11:24
07-17-2019 11:24
Didn't work for me either. But my steps are registering correctly on Step Bet, so it's another fitbit problem.
07-17-2019 11:38
07-17-2019 11:38
Try quitting the challenge and ask someone to re-add you... It worked for me. 🙂
07-17-2019 12:11
07-17-2019 12:11
I know this is now old but I still keep getting messages from comments. As the original poster I never marked this as solved so have no idea why it was. I never cheated I am aware that manually added steps would not sync in challenges. I was not new to fit bit and had had it for over a year when he issue occurred. What actually happened is fitbit phased out the model out so they stopped that model syncing correctly in order to make people buy a newer model. The model I had was the original flex which stopped being on sale 3 months before the issue
07-17-2019 12:24
07-17-2019 12:24
It worked but it's a one-time fix. Additional steps after doing this are not syncing.
07-17-2019 12:30
07-17-2019 12:30
Yes, it's whatever number of steps you have at the time you're re-invited. Fibbit is still responsible for fixing what they broke.
07-17-2019 12:37
07-17-2019 12:37
I did send a message and my steps are still not syncing to the work week challenge. I have also done everything else that had been suggested.
07-17-2019 12:41
07-17-2019 12:41
The challenge step sync and step update to the work week challenge stopped at the same time for everyone in my challenge.
07-17-2019 22:01
07-17-2019 22:01
Same here! Everyone's stopped syncing at the same time yet they show on our dashboards.
07-17-2019 22:40
07-17-2019 22:40
My challenge groups are having the same problem. The Workweek Hustle hasn’t done a sync in over 12 hours. I wonder if Fitbit is working on the issue??
