05-11-2020
06:30
09:40
05-11-2020
06:30
09:40
I’ve tried all recommendations. Nothing is working. It’s my 2nd charge2 fit it. It just suddenly stopped syncing. I am very disappointed since I had the same result from my first one and I had to pay to get a 2nd one. Still the same problem!
05-11-2020 06:37
05-11-2020 06:37
Annoying
Best Answer05-11-2020 06:38
05-11-2020 06:38
Will not sync to iPad since last nights update
05-11-2020 10:58
05-11-2020 10:58
My charge 2 won't sync, I have a iPhone x turned on and of phone turned off and on Bluetooth and now my phone can't find my charge 2 help
05-11-2020 12:39
05-11-2020 12:39
got mine to sync after I read a comment on how to restart my charge 2, once I restarted charge 2 and restarted my phone again it finally synced
Best Answer05-12-2020 02:36
05-12-2020 02:36
Cannot sync to either I phone or I pad. Bluetooth is on but will not connect to Fitbit.
05-12-2020 04:29
05-12-2020 04:29
How did you restart the Fitbit?
Best Answer05-12-2020 06:39
05-12-2020 06:39
Best Answer05-12-2020 06:55
05-12-2020 06:55
Best Answer05-12-2020 08:32
05-12-2020 08:32
Best Answer05-12-2020 08:52
05-12-2020 08:52
Best Answer05-12-2020 13:53
05-12-2020 13:53
I've had the same issue with my charge 2 since my iphone updated to 13.4.1. Sunday evening I deleted the fitbit app from my phone and downloaded again. I also restarted my phone, restarted my fitbit, reset my fitbit and also removed the charge from my profile and added it again. Nothing has worked. What is odd is that yesterday and today, the fitbit app on my phone updated once in the morning and then never again. My ipad is due to update but I'm hesitant to update since I want to see my data.
05-12-2020 14:16
05-12-2020 14:16
05-12-2020 17:06
05-12-2020 17:06
Place it in the charging unit, then while it is in the charging unit press the button. You should see the Fitbit logo when it restarts.
Best Answer05-12-2020 18:08
05-12-2020 18:08
It seems this happens to me too whenever iPhone has an update. I tried the Chat Support, and was told the company is diligently looking into solving this issue. When I asked how long, I was told to check back in 1 - 2 weeks. I wish I had saved the last forum assistance I had. Whatever it was that was recommended did the trick.
Best Answer05-12-2020 19:42
05-12-2020 19:42
Thanks. Your suggestion of removing the Fitbit from Bluetooth worked! Appreciate your help!
05-13-2020 01:05
05-13-2020 01:05
done that it has not worked!
Best Answer05-13-2020 01:06
05-13-2020 01:06
Didn't you loose all your data by removing the device from your system and readding?
Best Answer05-13-2020 01:29
05-13-2020 01:29
My fitbit charge 2 stopped working with my iphone 7 after the update during the night of 12 May. But my ipad still connected. Today my Ipad Air 2 seems also to have updated and I cannot sync with that either. My Aria 2 scale is apparently still syncing ok. I do see that the iPhone 7 is no longer listed as a compatible phone on the devices page for Fitbit. I have tried restarting fitbit, turning bluetooth off and on on phone and iPad.
I also can't sync with the web login page on my pc - can't see where to force a sync there.
Fed up!!!!!!! Will I loose all my data if I delete the charge 2 from my account and reinstall ? Will it help anyway?
Best Answer05-13-2020 01:52
05-13-2020 01:52
I thought I would but I just checked and it’s still there.
