09-07-2019
		12:39
		10:43
		09-07-2019
		12:39
		10:43
Anyone else having this problem? My Fitbit was syncing just fine a couple of weeks ago. My phone did have an update which I didn’t update right away but it has suddenly stopped syncing up. So I updated my phone thinking that was it but no. Checked that my app was up to date which it was and have contacted customer support only to be ignored and I’m getting super frustrated. It literally worked two weeks ago. I’m now reaching out on Facebook to try to get answers but this is just eye roll worthy. Help!
09-19-2019 09:47
09-19-2019 09:47
rebooted the factory reset?
 Best Answer09-19-2019 19:11
09-19-2019 19:11
 Best Answer09-19-2019 19:18
09-19-2019 19:18
 Best Answer09-19-2019 19:28
09-19-2019 19:28
So do you have a fix that none of us have already tried? I think I've tried it all by now. Thankzzzz.
 Best Answer09-19-2019 19:32
09-19-2019 19:32
Yes. I’m here to complain about the Fitbit ‘upgrade’? The new user interface is a bit anticlimactic compared to the last one, and also, my phone is having so many problems synching. It’s affecting my UX and I feel really disappointed. Pls fix the bugs & design better UI & UX. #notok
 Best Answer09-19-2019 19:48
09-19-2019 19:48
 Best Answer09-19-2019 19:57
09-19-2019 19:57
If you need more details I’d be happy to provide them @Fitbit
 Best Answer09-19-2019 20:20
09-19-2019 20:20
If you can fix this you'll be a hero
What have you got?
 Best Answer09-20-2019 04:45 - edited 09-20-2019 11:58
Details would be great, now my tracker 3 will now pair!
 Best Answer09-20-2019 04:46
09-20-2019 04:46
 Best Answer09-20-2019 05:06
09-20-2019 05:06
I did the factory reset on the tracker, and delete then reinstall the Fitbit app...hold both sides of the tracker until the screen changes. Scroll to settings, about, factory reset. This fixed my synch and time issues.
 Best Answer09-20-2019 05:35 - edited 09-20-2019 12:03
Ok, now I have app up but NO STEP, NO SLEEP, etc everything missing! Calling support again today. UPDATE, Called support today, we looked over my history and it was decided I would receive a replacement Charge 3, I hope to get it by Monday as this one now has no screen only black and all you can get from it now is a vibration every time you touch the button, otherwise it a blank, nothing , zero done! Fitbit is trying to make this right but so frustrating to deal with this.
 Best Answer09-20-2019 12:37
                              09-20-2019 12:37
The fix for a sync issue may be dependant on which OS the phone runs. As mentioned above their are general steps that work with all phones. The specifics steps we have found to help are very much OS specific.
 Best Answer09-20-2019 13:13
09-20-2019 13:13
I have a Galaxy S8 that it has been pair with for several months with no issues.
 Best Answer09-20-2019 14:39
09-20-2019 14:39
 Best Answer09-20-2019 15:35
09-20-2019 15:35
Mine started doing this yesterday. I have done everything it says to do on the app. Uninstalled it, unpaired it, Bluetooth off and on again, restarted my device and my phone. I want to know what is going on. Because when I reinstalled the app it said it found my device but wouldn't connect took me 3 attempts then it worked for all of 2 minutes (literally) now it's not and saying no device found yet again.
 Best Answer09-20-2019 15:46
09-20-2019 15:46
Ugh me too. Just updated iOS last night
 Best Answer09-20-2019 17:42
09-20-2019 17:42
I am on my second Charge 3 in one month. Neither of them ever synced properly. I had a HR Alta that synced as soon as I sat down in front of my PC instantly until it stopped in August. I upgraded. The first one didn't sync. After a half dozen calls to FB support, another was sent. That never synced easily either. I had to shut down my PC and remove the Charge 3 ever time and after an hour of attempts nightly, it would finally sync. I had a PC guru look at it. He said FB is not keeping up with the Microsoft updates. I waited for the big update a few weeks ago hoping that would help. Now all the "go to's" that I used to sync have stopped working as of Tuesday. Nothing works. A phone call to FB tomorrow will hopefully glean a third and last Charge 3 before I ask for a refund. It has only been since 8/27 and I have 45 days. Third time is the charm. I don't have a smart phone or laptop to use. Only my PC.
 Best Answer09-20-2019 17:48
09-20-2019 17:48
I would be happy if my Charge 3 just kept time and steps. The rest I don't need. But if you don't sync it at least a few times a week, it will start to loose time. I am a nurse and I need a watch that is accurate. I didn't sync for 2 days and it was 4 minutes off. What do I say to my patients. "Sorry I am 4 minutes late. I thought I was on time. My FB watch is loosing time." Looking at all the problems with FB, how can this company stand by it's product? To wait for the next update will take me out of my warranty to get my money back. And FB is not keeping my money for a product that does not work.
 Best Answer09-20-2019 18:25
09-20-2019 18:25
