12-18-2019
14:38
19:49
12-18-2019
14:38
19:49
Create a S/W update to allow FITBIT HR to sync only with blue tooth, without WIFI or clellular data . it cant be that hard if other fitness app suppliers can do it. This would solve a lot of sync problems
12-19-2019 00:20
12-19-2019 00:20
The problem with that is the way fitbit designed it. They chose to hold all the data on the fitbit servers so that you can use multiple devices to access it and it's all safe should you lose or change your phone.
So, to sync, you need bluetooth access to connect your phone to the fitbit but you also need internet access to connect to the fitbit servers.
Best Answer12-19-2019 08:09
12-19-2019 08:09
Best Answer12-20-2019 13:24 - edited 12-20-2019 13:27
Asking your fellow Fitbit users for help with an issue that will need to be handled by Fitbit....
You may want to go to the forum for giving suggestions to the Fitbit developers.
We so have a suggestion that votes may be added to.
Allow Offline syncing / Store data locally
Can you name a connected watch that works offline? Garmin and Apple don't.
12-20-2019 13:36
12-20-2019 13:36
Runtastic - Steps (Adidas) works and syncs offline. Also would allow to set the clock on the HR
Best Answer12-29-2019 14:40
12-29-2019 14:40
Thank you, but Fitbit is not runtastic. Did you vote for the suggestion for off line sync?
Best Answer12-29-2019 16:24
12-29-2019 16:24
