01-23-2017
23:01
17:01
01-23-2017
23:01
17:01
I am having trouble with my app on my android phone. I have been syncing my charge and the app says that it is synched but no information is showing up (steps, calories etc.) even though I can see that they are on my charge. I have tried deleting and re-downloading the app. I have made sure I have the most updated version, and i have tried logging out and in again.
HELP
01-24-2017 17:20
01-24-2017 17:20
Thanks for joining us @Hmah! This sounds odd. To ensure that your tracker is working correctly you can try to restart it. If this doesn't work please set up your tracker as a new device.
I hope this helps, keep me posted with the outcome! 😉
01-24-2017 18:56
01-24-2017 18:56
My charge hasn't sync since 2:54 Jan 23 on either my phone or on the computer. I have turned on and off bluetooth, plugged it in, restarted my phone logged in and out. uninstalled and reinstalled the software and NOTHING is working. Please provide a solution ASAP
01-24-2017 23:28
01-24-2017 23:28
I haven't had a successful sync on my Charge since 8:56 pm Jan 4. I have also tried all of the suggested fixes. What gives?
Oh yeah, my battery drained two days ago before I could get it on the charger and ever since I completed the charging the clock on the device is behing 5 hours 37 minutes
01-24-2017 23:53
01-24-2017 23:53
Trying to sync and it keeps saying no device found. Any idea what to do? I downloaded the app again. My device is tracking still but it won't update on my phone.
Best Answer04-28-2019 02:54
04-28-2019 02:54
Did you ever get an answer or able to get the data to push through the dashboard/phone? I've tried all of the suggestions and my data still shows zero even if sync was successful.
12-05-2021 15:29
12-05-2021 15:29
This intermittent issue is unreasonably frustrating. I will not buy another fitbit...ever.
