01-17-2020
10:02
17:44
01-17-2020
10:02
17:44
When I move my wrist to view time or stats, my Charge 3 does not wake as it used to. It wakes when I tap it. I have to slide through screens for each option, exercise, timers, alarms, etc. The screen awake is not there scrolling sideways or up and down from the main screen. How do I fix this? I use an IOS 13.3
01-17-2020 19:12
01-17-2020 19:12
MAYBE I fixed my own problem. I started all the steps to restart my device. When I plugged it in and held the button the screen awake and notifications showed up. As I guessed, screen awake was off. Once I turned it on again, my screen wakes up when I turn my wrist. ——Maybe this helps someone else.
01-17-2020 17:22
01-17-2020 17:22
instead of editing, you could have posted a response, then mark it as the best answer. This way you would help others.
Glad you found the setting.
Best Answer01-17-2020 19:12
01-17-2020 19:12
01-17-2020 19:15
01-17-2020 19:15
Thanks Rich_Laue.
Best Answer01-18-2020 08:10
01-18-2020 08:10
I don't see any "steps".
I am having same problem. I plugged it in but where do I see the "screen awake" function?
Best Answer01-18-2020 08:12
