01-18-2018
17:46
18:54
01-18-2018
17:46
18:54
All of sudden ,I keep getting Tracker not found message and unable to sync. Charge 2 and my phone is LG XPower. Already restarted twice both Charge 2 and phone. I've used the same Charge 2 and phone for 6 month, this issue started last night.
02-08-2019 22:07
02-08-2019 22:07
Exactly, alway had the same vibe here.
02-11-2019 04:44
02-11-2019 04:44
And there is zero consideration for the fact that the same people who are indicating a sudden issue with their Fitbit, often also indicate that there is zero problem with any other device or app associated with their phones
And yet, it *must* be a problem with something other than the Fitbit we are told
So how come the cache clearing, and app reinstalling, and device resetting instructions are only given for the Fitbit? Hmmmmm...
02-11-2019 04:54
02-11-2019 04:54
I started having the same issues again with the iPhone 8 and just gave up... No more Fitbit
02-11-2019 12:48
02-11-2019 12:48
I'm having the same issue here.
Having tried everything I could find to connect my phone to my fitbit (which had been happily paired for nearly a year) - restart phone, restart bluetooth, reinstall app etc etc. I eventually tried to connect it on my laptop.
New installation of the app on Windows 10, try to Add Device and follw the instructions but it just shows "Connecting" and never goes any further. Eventually it times out.
The laptop's bluetooth settings show that it can see the Charge 2, so its bluetooth must be working. So i can only presume that it is a problem with the app itself.
Any further suggestions or help appreciated
02-11-2019 13:03
02-11-2019 13:03
@BrainWaveCC these steps are being given because your fellow Fitbit users have discovered that they have fixed their issues.
Now unlike most apps, Fitbit embeds drivers into the OS, which might be why clearing cache has helped in the past. With the latest app update this so hasn't helped me.
@boyse7en once the tracker is setup to your Fitbit app, it normally will not need to be setup again. The should have been no reason to do an add device on the computer as long as you've logged into the correct account.
One thing that you would need to do is turn off the Bluetooth on the phone.
02-12-2019 06:39
02-12-2019 06:39
Hi @Rich_Laue
I was only setting it up again as it didn't work. After following these instructions -
If your Fitbit device still won't sync, try these steps:
and getting nowhere with it the only option i could see that i had left was to remove the device from my phone, reinstall the app and start from scratch again.
When that didn't work i thought I would try using a laptop in case the problem was my phone, rather than the Charge 2. Having tried the laptop app and it still won't connect to the Charge 2 I'm at a loss as to what to do. I have tried switching off the bluetooth on both phone and laptop, but no combos of off/on seem to work.
02-12-2019 13:28
02-12-2019 13:28
tried again this evening on my phone. made sure that Bluetooth was turned off on the laptop.
Uninstalled fitbit app. Reinstalled from Play Store. Went to Add Device. Selected Charge2 and follwed instructions. After about 10 seconds of whiring it found my Charge 2 and said it was Connected. The up popped a Bluetooth Issues warning dialogue and connection failed
