02-09-2020
05:48
10:23
02-09-2020
05:48
10:23
Traveled to different time zone. While your iPhone app notes the new time zone correctly, the fit bit still shows the original time? How do I make the change happen on my fit bit?
02-09-2020 06:02
02-09-2020 06:02
That would depend on your timezone settings @Ronales.
If set to auto timezone. After the phone's time updates, the tracker needs to be told through a sync.
If set to manual the user will need to change the timezone and then do a sync.
The problem with changing timezones is when jumping ahead, the user will skip an hour. This is not a big deal, but when the user jumps backwards the last hour gets overwritten and the user loses an hour of data.
I prefer to leave my timezone on the tracker alone, then add or subtract when looking at the watch.
06:36
09:26
AlvaroFitbit
02-09-2020
06:36
09:26
AlvaroFitbit
Probably best then to leave it alone!
Thanks!
Moderator edit: removed personal information
