10-20-2017
06:51
09:26
10-20-2017
06:51
09:26
Is there a way turn turn off the floor option so floors are not counted at all?
10-20-2017 07:21
10-20-2017 07:21
No there isn't. You could suggest that option here , preferably first searching if it is already there to add your vote to it.
I'm curious why you would want them completely off instead of just ignoring them.
12-20-2017 12:09 - edited 12-20-2017 12:16
I work on a train all day so going through tunnels seem to tell the charge 2 that I suddenly climbed 50 floors.
This messes up my calories count big time so I asked for the feature to turn it of when I had the charge 1.
But nothing yet. That is pretty lame fitbit!
12-20-2017 12:40
12-20-2017 12:40
I don't think they affect calories burned on the Charge 2 since it detects heart rate and calculates calories from that. On an earlier version without heart rate, I can see perhaps it would use that in calories but I think not on the Charge 2.
Curious about the tunnels. There must be a big change in atmospheric pressure in them.
Best Answer12-20-2017 12:54 - edited 12-20-2017 12:55
I have a calorie count of 3000-4000 a day so I thought it affected it but I could be wrong. This is my first day using it.
Yes you can really feel it in the ears when going through tunnels in 200 km/h 🙂
12-20-2017 13:17
12-20-2017 13:17
You could check that by looking on the dashboard at fitbit.com at the daily graph of floors and calories to see if calories do jump when you get the extra stairs.
12-20-2017 14:29
12-20-2017 14:29
I will as soon as I'm back. Now it's Christmas! 😀
Best Answer12-20-2017 22:27 - edited 08-16-2021 11:10
As @JohnnyRow stayed floor counts have never added calories. Even with the non heart rate trackers. Calories. . My guess it takes energy to keep the body balances when on the train.
Best Answer12-21-2017 05:29
12-21-2017 05:29
Oh, well I'm on my feet almost all day so I guess I burn a lot of calories.
I think I need to buy me a gainer protein supplement 😁
Best Answer05-11-2019 04:06
05-11-2019 04:06
Because the charge 3 doesn’t count them correctly I can walk a lap on a flat office loop of 30 feet and it tells me I did “great 5 floors “
05-11-2019 12:12
05-11-2019 12:12
Walking past air ducts could add floors.
Best Answer07-07-2019 19:27
07-07-2019 19:27
I have the same problem on the Charge 3 except I gain floors while driving or doing water aerobics. It's quite irritating. I found a recommendation on Fitbit that said you can put in the activity you were doing during the time that stairs were logged to override and remove the stairs but it does indeed change the calories burned when you make that change.
08-15-2021 02:54
08-15-2021 02:54
Fotbit does a vo2 fitness calculation when running. But it does not do the calculation when running hills. With all the stairs, it never does the calculation.
08-15-2021 04:31 - edited 08-15-2021 04:32
Fitbit has never used floor count on any calculation other than display for The user.
While on a run, GPS will be used to monitor
Yes @OvS123 SpO2 is the amount of O2 in the blood, why would going up hills keep the tracker from reading the SpO2.
Best Answer08-15-2021 05:08
08-15-2021 05:08
Apologies, my understanding might be wrong. Recommendation is from article : Go for long runs on flat terrain. (How do I get best cardio fitness score during runs?)
My understanding was that the same mechanism is used to determine flatness of terrain. And it also is that it needs flat terrain to properly calculate vo2. So I understand then that the sensor for flights of stairs is not used when determining flatness of terrain. That is good news as I then can totally ignore it.
I tried to implement the workaround (set execise to driving) but it then loses my steps as well which is not acceptable.
So if there are no effect than display. I can live with it by ignoring it. I have a shooting star badge (20 000 lifetime floors) 🙂
Best Answer08-16-2021 11:13
08-16-2021 11:13
I've never heard of using driving as a workaround for removing only stair counts.
It will also remove steps.
Also Stairs will not be added unless the tracker is also adding steps, something the bouncing train will be doing.
