10-15-2018
10:13
15:06
10-15-2018
10:13
15:06
Today I tried to use the exercise timer, and though I've reached my goal it is neither stopping nor exiting the screen. I have tried to swipe every which way, and all I am getting is stats on an exercise that has gone on for 3 times longer than the goal I set. I tried holding the side button and even just touching the screen, but so far nothing has made a difference.
The only thing I can do is change screens to see exercise stats (that are completely inaccurate at this point) - mph, mph avg, fat burn, and calories. I am able to see the main screen with the time, but I cannot bring up anything else, and I can't get the exercise tracker to stop.
Reading the manual, it sounds as if it should notify once the goal is reached and then stop. It did not stop.
Any help is appreciated.
10-15-2018 10:41
10-15-2018 10:41
Called customer support. Got it worked out.
If anyone else has this issue you specifically need to be on the timer screen and double tap the side button to bring up the pause screen.
10-15-2018 10:41
10-15-2018 10:41
12-22-2018 18:27
12-22-2018 18:27
nowhere in the manual does it explain this. Why would you have to call customer service to figure out how to do such a basic thing as exit one of the apps on the Charge 3?
12-30-2018 02:06
12-30-2018 02:06
Ha! I had the same problem just now. Did what you said and got back to the clock face. Thanks for writing up the solution!
01-01-2019 11:26
01-01-2019 11:26
Thanks for posting! Yep, it works to bring up new menu to pause or finish. Not intuitive at all.
03-16-2019 22:54
03-16-2019 22:54
thanks it helped me out
Best Answer01-08-2020 13:34
01-08-2020 13:34
There are no buttons on the charge 3!
Best Answer05-01-2020 15:54
05-01-2020 15:54
My fit bit has been working absolutely fine every day since ive had it, for some reason the past few hours it has not let me touch the sensitivity button at the side, it is not working what so ever, im stuck on an exercise i can not get off ive tried double touching basically everything to get off it, and its not happening.
Im really not happy please can someone help!
Everything else seems to be okay, it is vibrating still but its the sensitive button touch at the side that is not working what so ever
Best Answer08-23-2020 12:12
08-23-2020 12:12
could not get out of exercise program.. had to resort to doing what Stacy73 reported.. thank you Stacy73.
Also not able to get GPS to stop! think I am sorry I purchased this thing!
Best Answer01-03-2022 09:08 - edited 01-03-2022 09:09
Didn't work. Stuck on two zeros. Can only scroll through minutes and seconds. Very frustrating.. Got stuck in an endless loop of screens after taking a shower and forgetting to set water lock.
Best Answer01-03-2022 15:35
01-03-2022 15:35
Best Answer11-09-2022 10:33
11-09-2022 10:33
Hi Stacy, fantastic it worked for me on my Sense. I was at the point of buying another brand as I had factory reset my watch as other things were not working. After the factory reset the only thing left to fix was stopping the watch after exercise. I really had tried everything without success until I read your solution. What a shame it does not tell you this in the manual. Thanks again!
Best Answer12-04-2022 18:53
12-04-2022 18:53
This just happened to me to...Took me a minute to get the solution to work. Actually, had to double tap both side 'sensor' buttons super fast. Finally got the screen that says 'Finish'. I have the Inspire 2, so maybe that's the difference. At any rate, thanks!
