10-13-2021
04:38
07:32
CindyMFitbit
10-13-2021
04:38
07:32
CindyMFitbit
Hi,
I have a charge 3 that I haven’t used in a while. Have tried to charge however the screen is black and I am unable to restart (have tried when plugged in and not). When I press and hold I get a continuous vibration and nothing happens.
It also won’t connect to my phone as it says the battery is dead (despite the fact I’ve had it plugged in for several hours)
Please can you help?
10-13-2021 07:36
10-13-2021 07:36
@Beth2302 Welcome to the community forums.
Thank you for the detailed information and for the troubleshooting tried prior posting. If you've tried to restart your Charge 3 and the inconvenience has persisted, I'd recommend trying to perform a long restart. A long restart is different than the basic one and you can complete it by following the instructions below:
Hope this helps.
09:05
09:43
CindyMFitbit
10-13-2021
09:05
09:43
CindyMFitbit
This hasn’t worked
What else can I do?
Sent from my iPhone
This hasn’t worked.
The screen briefly came on and displayed 001 error
Now it has gone black again
Moderator Edit: Merged replies
Best Answer10-13-2021 09:52
10-13-2021 09:52
@Beth2302 Thanks for your reply.
I appreciate for trying the suggested instructions. Since the inconvenience has persisted, my best recommendation is contact our Support Team so they can look deeper into the issue and help you with this matter. You can contact them through chat or over the phone. Click here to get connected. Make sure to mention the steps you've followed, so they can help you from there.
See you around.
