06-03-2019
06:46
15:47
06-03-2019
06:46
15:47
My tracker has been replaced under guarantee and I cannot get past the set up screen when I tried to connect new one to my account. Won't do the update and just has set up screen on tracker. In my account, if I sync it appears to show my steps but nothing else. There are no flashlight green lights showing on the back of the tracker.
06-04-2019 12:15
06-04-2019 12:15
Hello @JackieinUK thanks for bringing this to my attention, let me give you a warm welcome to our Community Forums and a hand with your difficulties.
Seems odd that you're experienced difficulties with the setup process of your replacement Charge 2. If you haven't already done so, please check our help article: Why can't I set up my Fitbit device? and let me know how it goes. Such article includes a restart process, which should resolve the heart rate green lights that are not currently flashing.
Let me know if you have any additional questions.
Best Answer06-04-2019 23:25
06-04-2019 23:25
Best Answer06-05-2019 11:33
06-05-2019 11:33
I'm having the exact same problem - Fitbit replaced my Charge2 tracker as my original one suddenly stopped syncing and then would not pair again after I unpaired it to see if that solved the problem. Long story short, replacement has arrived today and I'm having the same problem as Jackie. I started the setup, got the 4 digit number to pair and then it said an update needed downloaded. The update will not work and the tracker will not work without the update. Please help as I'm losing the will to live!
Best Answer06-05-2019 13:50
06-05-2019 13:50
17:38
05:54
06-09-2019
17:38
05:54
Hello guys, I'm here to continue providing assistance with your difficulties, my apologies for the delay in responding your posts. Welcome aboard @Bairnschick and thanks for your reply @JackieinUK.
@JackieinUK I'm happy to know that your concern was resolved with the retailer where you bought your original Charge 2. Please do not hesitate to contact me back if you require further assistance with your Fitbit, I'll be here.
@Bairnschick Thanks for sharing your experience with me, certainly this is not a common situation. Can you please let me know if you tried the troubleshooting steps that were provided on my previous post? Also, which mobile device you're currently using to setup your replacement Charge 2? I'll be looking to your reply.
Keep me posted.
Best Answer07-03-2019 13:39
07-03-2019 13:39
Hi there
I just received my replacement today directly from FITBIT, same issue, taking ages trying to update then fails.
Should I contact customer service for another replacement?
Best Answer07-03-2019 14:02
07-03-2019 14:02
Best Answer07-03-2019 16:01
07-03-2019 16:01
I’m having exactly the same trouble with my replacement I’ve received from Fitbit today, it will not pair up. I have had to reinstate my old one.
07-04-2019 00:25
07-04-2019 00:25
just make sure that you have followed all the steps in the trouble shooting before contacting customer services, I performed all the steps, still couldnt get it to work, contacted customer services and they have raised a case for it.
07-04-2019 00:32
07-04-2019 00:32
07-04-2019 12:01
07-04-2019 12:01
Thanks for the advice, tried all the troubleshooting steps but nothing worked so rang customer service who were really helpful. They talked me through all I’d tried myself and agreed it was faulty so are sending another replacement.
Best Answer07-04-2019 12:41
07-04-2019 12:41
07-05-2019
16:57
06:08
07-05-2019
16:57
06:08
Hello all, it's a pleasure to continue providing assistance, my apologies for the delay in responding. Welcome aboard @KatieKitten. Thanks for your replies and updates @barbygal @JackieinUK.
I appreciate all the information that was shared in your posts, the patience and effort with this situation are appreciated. Follow these instructions if you already have a Fitbit account and want to replace your existing Fitbit device with a new one, or if you use more than one device connected to the same account. If you’re replacing one device with another of the same model, you’ll be asked to confirm the replacement. For instructions on how to remove a Fitbit device from your account, see How do I remove a Fitbit device from my account?. Also, I recommend to take in consideration the steps from my previous post.
If by any chance the issue persist after trying the above steps, please get in touch with our Customer Support team to receive further assistance.
I'll be around if further assistance is required. Keep me posted.
Best Answer08-10-2020 20:19
08-10-2020 20:19
For me emptying cache of app worked and settings. I found it in settings apps on my phone (for me in memory card location) Then I followed usual steps of turn off blue tooth restart etc.
12-18-2020 10:54
12-18-2020 10:54
I'm having exactly the same problem mentioned here so it can't be that uncommon. My Fitbit froze one day on the Fitbit icon. A replacement was sent. I followed the instructions and got the code. Syncs fine, connects fine but screen frozen on Fitbit icon and welcome screen. Tried again from scratch same result. Rebooted fitbit same screed appears.
