05-24-2022 09:38
05-24-2022 09:38
How do I update Charge 3 Firmware?
05-24-2022 09:48
05-24-2022 09:48
When there is a firmware update available for you, you will get a very obvious notice on phone app telling you how to do the update. If you think you are not up to date on firmware, be aware firmware updates roll out slowly; it can be quite a while before it gets to everyone.
Best Answer05-24-2022 09:48
05-24-2022 09:48
Best Answer05-24-2022 09:55
05-24-2022 09:55
Hello @Rrutkowski
If you wish you can manually check if your Charge 3 needs a firmware update. Open your Fitbit App, tap your profile picture then scroll down to and tap Help & Support. Now scroll to the bottom of the page and tap “Check for Charge 3 Update”.
05-25-2022 04:01
05-25-2022 04:01
@Rrutkowski The current firmware for the Charge 3 is v 1.88.11. You can verify your version by tapping on your profile picture, then your Charge 3 image. It was released in 2020.
Laurie | Maryland
