02-02-2016
17:47
17:10
02-02-2016
17:47
17:10
02-02-2016 17:53
02-02-2016 17:53
Hello @nikster12,
This actually depends on the model of your tracker. I don't have a Charge, so I don't know for sure. To check:
If available, it'll be on this page. I hope this helps.
Frank | Washington, USA
Fitbit One, Ionic, Charge 2, Alta HR, Blaze, Surge, Flex, Flex 2, Zip, Ultra, Flyer, Aria, Aria 2 - Windows 10, Windows Phone
02-03-2016 05:57
02-03-2016 05:57
Hey @nikster12 welcome to the Forums! In fact, Fitbit Charge features a celebration when you reach your daily goal. As @PureEvil mentioned you can find the option at your dashboard settings. Please see the images below for reference.
Also, make sure you have set the appropiate amount of steps at your "Activity Goals" tile.
Let me know how it goes! ![]()
Was this what you were looking for? Vote for it and mark it as an Accepted Solution!
05-03-2020 14:45
05-03-2020 14:45
how do I make it viberate
Best Answer09-24-2020 19:46
09-24-2020 19:46
Mine stopped vibrating onon thethe lady update. Sucks
10-11-2020 11:20
10-11-2020 11:20
Mine did too. Not sure how to make it work anymore. My friends still vibrates when she gets to 10k steps. She and I walk together everyday to get our 10k steps and I have to keep checking on mine while hers vibrates to let her know. I can't seem to find a solution on the mobile app.
12-15-2020 05:51
12-15-2020 05:51
The same issue occurred with my Fitbit. I updated it and now I get no 10k step notifications even though it’s my daily main goal and set to notify. FiTBIT, can you fix this issue?
12-15-2020
08:36
07:50
12-15-2020
08:36
07:50
@nikster12 It's great to have you here!
Let me help you with this. Make sure that your tracker isn't in the Do not Disturb mode by long pressing the button. You can also change the step goal to a different number, save and sync then change it back to the desired amount, save and sync again. Finally restart your tracker.
Let me know how it goes.
02-19-2021 16:49
02-19-2021 16:49
Mine stopped vibrating at my daily step goal too (10,000), also the vibrate reminder to move stopped. I tried your suggestions here; will see if they work.
02-21-2021 03:56
02-21-2021 03:56
Long hold the button on your Fitbit. You will get the icons for DND (do not disturb) and Sleep. Make sure they are both shut off. If they are on they will be lit. Tap them to shut them off (a line will go through each one) and they will fade.
02-21-2021 12:55
02-21-2021 12:55
Best Answer02-21-2021 14:40
02-21-2021 14:40
