06-30-2019
21:27
15:06
06-30-2019
21:27
15:06
Hi! My charge 2 just stopped working a few days ago, the sleep tracking isnt getting details and the battery went from 7 days to about 5 hours overnight. I fully charged it this morning and it died on my 6.5 hour work shift. I know I purchased the extended warranty, but I dont know where to look for that info or how to see when I purchased it (so I don't even know of the warranty is still good). Where can I find this info? Thanks in advance!
07-01-2019
08:35
10:30
07-01-2019
08:35
10:30
@Dreadeddragon Welcome! It's nice to have you on board!
Let me help you with your Charge 2 not working correctly. For the battery issues try cleaning the contacts using cotton with rubbing alcohol then charge it by plugging it for a couple of hours directly to your computer's usb port (try different ports) or use an UL listed usb wall adapter. After this, restart your device and see how it behaves.
Regarding sleep details (sleep stages), you may not get them for the following reasons:
Finally you should have the details from your extended warranty from your purchase email. Still you can check it's terms and conditions and how to contact the provider here.
Let me know how it goes.
Best AnswerI've had this thing for nearly 2 years and I've not once had this problem before. The heart rate sensor also stopped working, which is probably the reason for the sleep tracker, the green lights are a constant steady glow. Unfortunately the link you sent for restarting the device doesnt work, but its turned off plenty of times due to the battery only lasting a couple of hours.
I was supposed to keep an email in my inbox for 2 years? (No snark intended, this is a legit question). Is there a way to tell when exactly I purchased my fitbit if I bought it from the app/website? If it's been over 2 years there's not a point to trying to figure out the warranty. I dont see anywhere on the website or the app that will show me previous purchases, but maybe it can be seen from an admin?
Thanks for responding so quickly!
