09-12-2022
07:41
15:10
LucioFitbit
09-12-2022
07:41
15:10
LucioFitbit
So, it used to be that I would set a weight goal and the widget on the app would show the pounds lost ONLY. When I met that goal, I would set another but the amount of weight lost on the widget wouldn't reset, it would just continue to track the overall pounds lost. (ex. I lost 10 lbs, the widget shows 10 lbs lost. I reset the goal to another 10 lbs, the widget now shows 20 lbs lost).
This morning, I met my weight goal so I set another one (and the weight lost was showing on the widget) and NOW the widget on the app shows my current weight!! It didn't this morning and I don't want it to. Also, now that I've set a new goal, the pounds lost number also no longer shows. What changed??
12-27-2022 15:13
12-27-2022 15:13
Hi there @Rosiepoo, it's good to have you in the Community.
I understand how you feel about this situation. I'd recommend you check these articles, How do I track my health and fitness goals with the Fitbit app? and How do I add, edit or delete Fitbit data and Activities?.
Also you can restart your device.
