07-10-2022
19:23
14:11
07-10-2022
19:23
14:11
Every time I wear my Charge 4 to bed or to do an exercise, the clock face changes. I simply want it to show the time and my total steps for the day. I wake up and it will show the time and calories burned, or the time and floors climbed. I have to manually go in and change it. Why is this happening? I put it on sleep mode when I am in bed.
07-11-2022 03:19
07-11-2022 03:19
Hello @joans1976! Your clockface can show different stats when you tap on the screen or if it occasionally brushes against fabric. All you have to do is tap over the miles or calories and it'll cycle through the other stats until you get to steps. I know that's a little annoying, but the only way to prevent this is to try to find a different clockface that doesn't have multiple stat options and only shows time and steps (I'm not sure if that kind of clockface exists).
Best Answer07-11-2022 03:19
07-11-2022 03:19
Best Answer07-11-2022 17:41
07-11-2022 17:41
Okay, thanks for the tip. That is annoying to have to tap through. Otherwise I’m happy with my Charge 4.
