03-26-2020
13:25
10:02
03-26-2020
13:25
10:02
Can I make "workout" or "aerobic workout" one of the exercises I can pick to track and time on my charge 2? It says aerobic workout is an auto tracked item, but I find it really inconsistent. One day gets tracked, another day doesn't. I'd like to be able to select it on my device.
03-26-2020 14:34
03-26-2020 14:34
Welcome to the forums!
Under settings then exercise shortcuts make sure Workout is one of them.
(Aerobics is not listed)
It needs to sync before it takes place on your device. Once it does you can name it to want ever you want. Aerobics is listed under all the exercises
Hope that helps!
Wendy | CA | Moto G6 Android
Best Answer03-26-2020 14:34
03-26-2020 14:34
Hope that helps!
Best Answer03-27-2020 10:23
03-27-2020 10:23
Thank you WendyB. My problem was that I was trying to find how to do something like this on my phone. Turns out I had to open the app on my laptop to change these preferences. This worked like a charm, and I'm now all set. Thanks again. Much appreciated!
05-16-2021 15:18
05-16-2021 15:18
Just be careful doing this without an expert near you just so you don't get hurt...
