06-04-2016
05:00
20:15
06-04-2016
05:00
20:15
06-13-2016 04:21
06-13-2016 04:21
I finally fixed this issue by 1) uninstalling the app from my iphone 6; and 2)reinstalling the app and then disconnecting my charge HR and re-pairing it up. Once I went through the set up again the clock and the date appeared as the right time. Phew....10th time lucky 😉
06-04-2016 05:01
06-04-2016 05:01
06-05-2016 12:23
06-05-2016 12:23
@Dmed Welcome to our Community! You will need to sync your tracker to correct the time on it. Try restarting your tracker again but do this 3 times in a row by following these instructions:
1.- Plug your charging cable into the USB port and insert the other end into the port on the back of your 2.- Fitbit Charge HR. Your Charge HR will begin charging.
3.- Press and hold the button for 10 to 12 seconds until you see the Fitbit icon and a version number (e.g. "V30").
4.- Let go of the button.
5.- Unplug your tracker from the charging cable.
If the issue persist then please try these suggestions.
Let me know how it goes!
06-13-2016 03:37
06-13-2016 03:37
unfortunately none of these suggestions have worked. my fitbit charge hr is still showing the wrong time and date - any other suggestions? unfortunately it has just gone out of warranty 😞
06-13-2016 04:21
06-13-2016 04:21
06-22-2016 08:07
06-22-2016 08:07
06-22-2016 10:34
06-22-2016 10:34
@Steen57 Welcome to our Community!
@Dmed Great to hear that your tracker is working as it should and thank you for sharing the steps you took to fix this issue.
@Steen57 This is normal and the number you see is the firmware version of the device. After this try syncing your tracker to make sure the time gets updated.
10-03-2016 17:06
10-03-2016 17:06
My Charge HR is also showing the wrong time / date. I have tried syncing the device but for some reason the dongle is not working so I can sync it. What can I do ??? Your help is greatly appreciated.
10-05-2016 07:08
10-05-2016 07:08
@BAT05 Welcome to our Community! Since you haven't synced your tracker (I guess for some time now) then your tracker lose the correct time but this will be corrected once you sync it again. Try plugging your USB dongle to a different usb port on your computer and you could also restart your computer. Also make sure you have the most recent version of the Fitbit Connect software installed. If your dongle still doesn't respond then please contact our Support Team for further assistance. If you have a compatible mobile device then you could use it to sync your device. Or if you have bluetooth on a Windows 10 or Mac computer you should be able to use it to sync your tracker with it. Remember to also try restarting your tracker following the steps in my previous post.
10-28-2016 11:38
10-28-2016 11:38
Whew!!! I thought all my hard work went down the drain... It worked perfectly, time is still a min off , but the rest of the info was recovered..... Thanks a lot
11-01-2016 07:31
11-01-2016 07:31
@2Fine Happy to hear that your tracker is now working! If you have time please check our Discussions board where you will find great tips and recipes shared by other members.
Hope to see you around!
11-03-2016 14:50
11-03-2016 14:50
Man what a pain! This is not user friendly at all!!!
11-07-2016 05:08
11-07-2016 05:08
@rallen76969 Welcome to our Community! Sorry about the difficulties you are encountering. What issues are you having with your tracker? Have you tried the instructions mentioned in this thread? Which troubleshoots have you tried?
11-07-2016 09:08
11-07-2016 09:08
This post was helpful. The solution to fix the problem is an issue. Fitbit should really do something to fix this issue.
11-07-2016 19:30
11-07-2016 19:30
I have tried all the solutions mentioned but fitbit is still showing wrong time. Only 10 minutes slow, but it is frustrating as I use it as my watch and it's wrong. Why would it suddenly lose time? And it is possible it may lose more time, so now it's unreliable.
11-07-2016 20:03
11-07-2016 20:03
04-13-2017
21:26
05:15
JuanJoFitbit
04-13-2017
21:26
05:15
JuanJoFitbit
What if I don't have an iPhone. These solutions are all for other devices, not a desktop.
I have the same issue and it has not changed no matter what I do with plugging in and unplugging. Still two days slow.
Moderator edit: merged reply
04-14-2017 05:38
04-14-2017 05:38
My HR is showing the wrong time, however it is syncing correctly. I have attempted to reset it as suggested but that has not resolved the issue. The time on my phone is correct, but the time on my HR is an hour behind. If I watch the HR and the app sync, the app will say last synced an hour ago when it finishes. Something is off and I do not know what it is.
12-01-2019 13:13
12-01-2019 13:13
yes wrong and time 6 hours be hind
04-01-2020 11:17
04-01-2020 11:17
Wrong date and time
