10-09-2019
01:30
12:16
10-09-2019
01:30
12:16
My Fitbit is showing the wrong time, so I tried to re-sync it to my phone. But it says that the Bluetooth is not on. I checked and it is.
Any ideas?
10-09-2019 09:03
10-09-2019 09:03
Hello @hazele123 how long ago does the app say that your Charge 2 has synced?
Is the Bluetooth on your phone turned on? If so i would try a restart of the phone.
10-09-2019 15:17
10-09-2019 15:17
Still using America time. I want to change to Australia time.
Best Answer10-10-2019 00:49
10-10-2019 00:49
@Litusula19 i assume that your in Australia. Have you checked to see if your location is correct then i suggest what others have found to work. Change the location to something else, sync, then change back to the correct one.
