10-09-2019
09:00
12:06
10-09-2019
09:00
12:06
My Charge 2 is now completely dead with no explanation. I tried charging it overnight -- didn't vibrate or acknowledge charging (because it's dead). When I woke up it was hot to the touch and still just an expensive paperweight. Can't get it to charge much less restart. I purchased at a local Walmart store less than 5 months ago, and it doesn't look like the Fitbit policies cover outside purchases. This is the second one that's bricked on me in less than a year -- done with Fitbit.
10-10-2019
08:12
07:04
10-10-2019
08:12
07:04
@LisaArnold Welcome! It's good that the community is growing!
Let me help you with your unresponsive Charge 2 and thank you for troubleshooting this issue. I have created a ticket so our Support team can further assist you via email. They will check the warranty and provide options.
Let me know how it goes.
Best Answer10-10-2019 16:10
10-10-2019 16:10
Mine bricked at 14 months. I pretty much decided I was done with Fitbit, although I like the app/software better than others. Then I got invited to join an ArthritisPower study, and I'm setting up a new Versa right now for that. Will see how that goes. I really like the Charge 2 feature that gives you altitude gain, but the screen scratched if you breathed on it. Wish this company would get it together. I had that one that got recalled, which I LOVED, and I had a One that was great except for being so easy to lose or run thru the washer. Sigh. Here I go again with the Versa.
Best Answer10-11-2019 17:39
10-11-2019 17:39
i have the same stupid problem also, mine just passed its 1 year warranty. its upsetting that you spend the $$$ and they don't even last a stupid year. i still have my original charge hr #1 and that one is still working somehow. so i dont know what they did wrong. i ordered another charger hoping that it might help but i doubt it. back to samsung for me
10-12-2019 05:19
10-12-2019 05:19
Yes it is so frustrating that many users of the Charge 2 are reporting problems with their tracker just dying as the batteries appear to have such a short shelf life and all Fitbit can do is respond with standard advice to clean the Charge points. No acknowledgement of an inherent problem or possible recall solution.
10-12-2019 14:29
10-12-2019 14:29
I'll have to take a closer look at Samsung when the Versa fails. I would not have bought it myself, but it was provided as part of the study I'm participating in. I really prefer something that includes altitude gain and don't care if it's waterproof.
Best Answer10-12-2019 18:33
10-12-2019 18:33
I'm having the same problem. I've cleaned the charging pins and everything. I've reset it. It tells me the battery is full. Then I put it on and it's dead. This is obviously a common problem. And what's unfortunate is that it's a common problem shortly after the warranty runs out which makes me wonder if that's why they only gave a 1 year warranty. Hey Fitbit, please help me fix this issue! And if the Charge 2's have a faulty battery please just save everyone some time and stress and issue a recall.
10-13-2019 00:37
10-13-2019 00:37
I think I might try a Garmin now.
10-13-2019 00:41
10-13-2019 00:41
Yes the silence from Fitbit on this issue is appalling. The fact that adverts for replacement batteries for the Charge 2 and online tutorials on how to fit them clearly shows a fault that Fitbit is ignoring. I still have an original Fitbit flex that nearly 5 years on still holds a full charge. Will not replace with another Fitbit and am sharing my concern with friends and colleagues with trackers.
