10-19-2019
11:46
12:06
10-19-2019
11:46
12:06
third charge HR 2 has bit the dust again!! This is a massive design flaw in my opinion as every one
separates at the junction between the wrist strap and the fitness tracker with normal use. Starts as a small separation and progresses until almost completely apart. Tried to save it with electrical tape when it started but only got an extra 1-2 months. Anyone else with same issue. Suggestions for better tracker options to this costly annual expense. As a health care practitioner I cannot recommmend my patients
spend the money on this one
10-19-2019 12:19
10-19-2019 12:19
It wouldn't do any good to recommend it anyways since it has been discontinued, assuming you mean the Charge 2.
You can buy replacement straps inexpensively on Amazon.
Best Answer10-19-2019 16:11
10-19-2019 16:11
Best Answer10-19-2019 16:17 - edited 10-19-2019 16:18
@maryb2 wrote:
can't replace band on charge HR 2 but appears maybe on charge 2
Then you must be talking about the Charge HR, with no "2" involved.
There was a Charge and a Charge HR. It is hard to keep track of the names of all the different versions.
Bands on all the versions now for sale are replaceable.
Best Answer10-19-2019 16:48
10-19-2019 16:48
