10-05-2016
10:48
10:26
10-05-2016
10:48
10:26
Trying to sync my Chage 2 with my iMac. OS 10.11.6, the computer can not find the tracker. I have restarted the Charege 2 and turned iMac's Bluetooth off and back on .
10-06-2016 10:39
10-06-2016 10:39
Got it working, the preogram was finding my old Flex whixch is not connected with my account anymore, took it out to the garage. I notice that there can not be 2 or more bluetooth devices near each other or the Charge 2 will not connect ot any of them.
10-05-2016 11:59
10-05-2016 11:59
Hi @Jackk5,
Out of curiosity, are there any other Bluetooth devices paired to your Mac?
Also, I'd recommend the following steps to help with your Charge 2 syncing to your Mac:
1. Try to force sync your tracker using Fitbit Connect.
2. Turn Bluetooth off and then back on.
3. Restart your Charge 2.
4. If you sync using a mobile device, make sure that it isn't near your computer and make sure that your mobile device's Bluetooth is turn off.
5. If steps 1-4 don't help with syncing your Charge 2, I'd then recommend reinstalling Fitbit Connect as a last resort. Click here for instructions.
Hope this helps.
10-05-2016 12:15
10-05-2016 12:15
10-05-2016 12:32
10-05-2016 12:51
10-05-2016 12:51
10-06-2016 10:39
10-06-2016 10:39
11-20-2016 03:31 - edited 11-20-2016 04:00
I'm having the exact same problem as Jack. Tried to install on my Android phone (and was unable to connect to a device but assumed the os was too old, so uninstalled the app).
I then tried installing on my Mac, and when I get to the part where you get to "Synch Now" it tells me my Bluetooth is not setup - I have switched it on and off .... but can't get past that point in the installation 😞 The Mac bluetooth simply won't recognise the device.
This is my first device too 😞
11-20-2016 15:26
11-20-2016 15:26
I am also having this issue
11-20-2016 15:40
11-20-2016 15:40
@SunsetRunner and @katysh, does your Macs have built in Bluetooth?
Also the last time I saw a screenshot of the Bluetooth needs to be setup, there was a button under the message that said setup Bluetooth.
11-20-2016 16:16 - edited 11-20-2016 16:17
Screen shot?
11-21-2016 00:34 - edited 11-21-2016 00:35
yes my mac has built in Bluetooth.
The screen image I see, is en "error message" saying set up your bluetooth first before synching ... but there is no sign of a button on that screen.
I see there is also reference to a dongle that can be used with the pc, but my device didn't come with one. Does anyone know if a dongle should have been included in the package?
12-03-2016 08:25
12-03-2016 08:25
yes, you'll be hapy to hear the company does not include the dongle you need to connect your charge 2 to your computer. luckily they also do NOT tell you this on the package when you purchase the charge 2 so you at least are well prepared. it's also quite inconceivable that a device that costs $150 can not concect with an apple product (aren't the likely users likely the same??) without the purchase of another device to keep track of? what are the people at fit bit thinking? no wonder the stock is tanking
01-07-2017 10:23
01-07-2017 10:23
Derrick,
My Charge 2 won't sync to my iMac OS El Capitan version 10.11.6. My bluetooth on my computer syncs to speakers so works fine but it won't sync to the fitbit. I've turned the bluetooth off & on, reinstalled & rebooted but it still won't work and my purchase didn't come with a dongle. Thnks, Andrew
01-07-2017 14:32
01-07-2017 14:32
@Andrew5 do you also sync through a phone?
If so you will need to move the phone 30+ feet away or turn its BT off
06-18-2017 06:23
06-18-2017 06:23
Fitbit needs Bluetooth version 3.0 or greater. 2.1 will not work.
09-03-2017 12:13
09-03-2017 12:13
Thank you for being able to make the real issue clear. Are there older versions of Fitbit Connect which are compatible with 2.1?
12-10-2017 21:16
12-10-2017 21:16
The software version or the LMP version.??
02-15-2018 07:08
02-15-2018 07:08
I had the same issue where my iMac could not see the charge 2. I tried all the suggestions listed in this post. Contacted Fitbit and they sent out a dongle for free (great customer relations!). After plugging it in, it did a quick update and then synced without any issues. One note, I made sure my iPhone Bluetooth was off before syncing the Fitbit with the iMac.
04-23-2020 01:27
04-23-2020 01:27
This is not solved
04-23-2020 04:34
04-23-2020 04:34
