07-20-2019
07:02
10:55
07-20-2019
07:02
10:55
what is the difference between water resistant and waterproof in the description of the the charge 3. I am worried about wearing it in the pool.
07-20-2019 07:06
07-20-2019 07:06
The phrase "waterproof" isn't really used any more. Instead, there is a rating of water resistance that gives the depth of water that the item is safe in. The Charge 3 is rated to 50m depth as noted in the following help file: https://help.fitbit.com/articles/en_US/Help_article/1598/ so is quite safe for use in the pool.
07-20-2019 07:06
07-20-2019 07:06
07-20-2019 07:29
07-20-2019 07:29
11-01-2019 16:16
11-01-2019 16:16
I use the charge 3 in the pool; however, what do you want it for...I didn’t realize when I bought mine but all it shows on the screen is elapsed time. It will not give you any information about laps on the watch while you are swimming. Once it has synced to the app you get info but nothing while you are swimming. I did ask if this could be an update to the software on the charge 3 to at least give laps.
11-01-2019 18:52
11-01-2019 18:52
01-16-2020 06:11
01-16-2020 06:11
Hi.
I was wondering if your request for laps / lap times was incorporated into newer versions of the software since you posted?
01-16-2020 06:21
01-16-2020 06:21
