12-18-2016
08:55
20:15
12-18-2016
08:55
20:15
I have a replacement fitbit hr and for some reason it won't sync with my old account. I've followed the instructions several time and to be honest it's doing my head in. It just says not working. Help
12-18-2016
10:57
04:46
MarcoGFitbit
12-18-2016
10:57
04:46
MarcoGFitbit
I also have a replacement Fitbit and it won't show phone calls and in the last 4 days it will not sync! Please help, I love my Fitbit and want it to work properly.
Moderator Edit: Format.
Best Answer12-18-2016 15:50
12-18-2016 15:50
I just recieved my replacement HR, too. It synced for the first hour after it was connected - and will not sync since. I totally depend on my fitbit - I need it to work as it is intended.
Best Answer12-31-2016 04:51
12-31-2016 04:51
Hello @hayley01, it's great to see you around. Welcome to the Community @katklub99 and @Mforner, thanks for joining us! ![]()
I would like to provide you some tips in case your tracker is still not syncing correctly:
I hope this information can be helpful, give it a try and keep me posted! ![]()
Best Answer01-02-2017 12:30
01-02-2017 12:30
Hi I had to get another replacement fitbit.
Best Answer01-03-2017 05:31
01-03-2017 05:31
Hello @hayley01, I hope you're doing well.
Thank you for replying and letting me know about the outcome provided by our Support Team. In case you need anything else, feel free to reply, I'll be happy to assist you. ![]()
Additionally, in case you have some spare time, I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members. Happy stepping!
Best Answer01-03-2017 06:00
01-03-2017 06:00
Hi I just read your message about syncing a new fitbit to an account and wanted to ask you a question.
I've had a replacement Charge HR and when I try to add it to my account I constantly get a message stating that the Fitbit server is busy - do you know how I can get around this?
Many thanks
Best Answer01-04-2017 03:25
01-04-2017 03:25
Hello @Sarasaff and welcome!, it's great to see new faces around. ![]()
Have you removed your previous tracker from your account already? If not, please open the Fitbit app, tap on the Account tab, select your old tracker and at the bottom of the screen you will find the option to remove it. Then, please go to the Bluetooth settings on your phone and check if your old tracker is on the paired devices list; if it is, tap on it and select Forget this Device. Restart your phone and then try to set up your new tracker once again.
In case that doesn't do the trick, log out from the app, restart your phone and log back in. This should refresh the information incoming from the Fitbit server.
Give it a try and keep me posted in case you need anything else! ![]()
Best Answer01-05-2017 02:46
01-05-2017 02:46
Best Answer04-15-2020 07:22
04-15-2020 07:22
Did this ever get an answer? I am having the same issues, have done everything listed already. Any help anyone??
